problem with sony remote code...
karthickiw
PostPosted: Thu May 29, 2008 8:41 am     Reply with quote
hai friends,
i try sony decoder program from code library , i modified as my PIC and crystal.
program is decode the signal and give the data in RS232 port, but received data is not correct data. please check the program and give correct solution..
#include <16F873A.H>
//#include <lcd.c>
#fuses xt,nowdt,noprotect,noput,nolvp
#use rs232(baud=9600,parity=N,xmit=PIN_C7,rcv=PIN_C6,bits=8)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#ignore_warnings none
#zero_ram
/* TIMER0 configuration */
#define TIMER0_CONFIG   RTCC_INTERNAL | RTCC_DIV_1
/* Interrupt rate:                     */
/* 4/32000000*65536*1 = 8.192 ms       */
/*     Start: 3.0 ms (ignored)         */
/*     "1":   1.8 ms (14400)           */
/*     "0":   1.2 ms  (9600)           */
#define ONE_MIN  13400
#define ONE_MAX  15400
#define ZERO_MIN 8600
#define ZERO_MAX 10600
//#include "lcd.c"
/* irframes[0] (start) will be garbage, ignore it...  */
int16 irframes[13];
int8 ircount = 0;
int1 irdone = FALSE;
#int_ext
void ext_isr() {
  if (irdone) return;
  irframes[ircount++] = get_timer0();
  if (ircount >= 13)
    irdone = TRUE;
  set_timer0(0);
#int_timer0
void timer0_isr() {
  disable_interrupts(INT_TIMER0);
#separate
int1 decode_ir(int8 &addr, int8 &cmd) {
  int8 i;
  int8 mask;
  int8 bits[13];
  addr = 0;
  cmd = 0;
  for (i=1; i<=12; i++) {
    if ((ONE_MIN <= irframes[i]) && (irframes[i] <= ONE_MAX))
      bits[i] = 0x01;
      if ((ZERO_MIN <= irframes[i]) && (irframes[i] <= ZERO_MAX))
        bits[i] = 0x00;
      else        // Error
        return FALSE;
  mask = 0x01;
  for (i=1; i<=7; i++) {
    if (bits[i])
      cmd = cmd | mask;
    mask <<= 1;
  mask = 0x01;
  for (i=8; i<=12; i++) {
    if (bits[i])
      addr = addr | mask;
    mask <<= 1;
  return TRUE;
void start_ir() {
  memset(irframes, 0x00, sizeof(irframes));
  ircount = 0;
  irdone = FALSE;
void main() {
  int8 addr, cmd;
  int1 ok;
  setup_adc_ports(NO_ANALOGS);
  setup_adc(ADC_OFF);
  set_tris_a(0b11111111);
  set_tris_b(0b11111111);
  set_tris_c(0b11111011);  // PIN_C2 used for the LED
  setup_spi(FALSE);
  //setup_wdt(WDT_OFF);
  output_bit(PIN_C2, 0);
 printf("\fWaiting...");
  setup_timer_0(TIMER0_CONFIG);
  ext_int_edge(0, L_TO_H);
  enable_interrupts(INT_EXT);
  start_ir();
#ignore_warnings 203
  while(TRUE) {
#ignore_warnings NONE
    if (irdone) {
      ok = decode_ir(addr, cmd);
      printf("\fCmd  %3u\nAddr %3u", cmd, addr);
      if (!ok)
         printf("  ERROR");
        output_bit(PIN_C2, 1);
      delay_ms(50);
      start_ir();
PostPosted: Thu May 29, 2008 9:05 am     Reply with quote
Yesterday you did a post for RC5 and now for the Sony protocol, you are just fiddling around?
- When you copy code from somebody else then it is polite to keep the original author's name in the code.
- You make it a lot easier for us to find an error when you post the link to the original code so we can compare the differences. The original code can be found here.
- What behaviour do you see and what is expected?
- What does your hardware look like and how is it connected?
Hint:
When you reduced the clock rate from 32MHz to 4MHz you should have adapted these timings too.
