Rs232 routine problem on 16f876
marco niccolini
PostPosted: Thu May 29, 2008 4:22 am     Reply with quote
The rs232 reading routine doesn't work in my project. It must listen to com port to receive data from pc, but it goes just one time. After the first data transfer the pic became deaf to rs 232.
Have you any ideas?
The finnaly project source dode and hex file:
http:/ / digilander.libero.it/discoroller/rotore/ultimo.h
http:/ / digilander.libero.it/discoroller/rotore/ultimo.c
http:/ / digilander.libero.it/discoroller/rotore/ultimo.hex
PostPosted: Thu May 29, 2008 6:24 am     Reply with quote
Sigh!
If you really want to get some help, please reduce your problem to a small, fully-compliable test program that shows the problem. Making us go off to see your code somewhere else is BAD form, especially when (as a guest) you must use a "stealth" URL which can not be simply copied and pasted.......
My $0.02!
Dick
