PIC16f676 Internal Oscillator problem.
dani
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger MSN Messenger
PostPosted: Mon Jun 09, 2008 5:37 am     Reply with quote
Hello all,
I have written a code to generate 50 Hz flip flop pulses through PIC16F676. I have used internal oscillator for this. The results are not coming correct in terms of pulse timings(width). it seems that some pic after programming work well and on another it doesn't. Is this due to internal oscillator or am i doing some thing wrong some where . Plz Help.
Regards
Dani
PostPosted: Mon Jun 09, 2008 1:45 pm     Reply with quote
Post a short but complete (and compilable) program that shows the
problem. Also post your compiler version.
dani
PostPosted: Tue Jun 10, 2008 6:55 am     Reply with quote
#include "D:\CURRENT_PROJECTS\UPS\pp676.h"
#define BttlowInd     PIN_C5
#define RelayBttChrg  PIN_C2
#define UPSLED        PIN_C3
#define LEdWapda      PIN_A4
#define PUSH          PIN_C4
#define PULL          PIN_C1
#define WapdaIn       PIN_A5
#define Buzzer        PIN_A3
#define FAN           PIN_C0
#define BttCh 1
#define MainCh 0
int1 Flg,WapdaFlg=0,FlgChrg,FlgUps=0,chrgFlg=0,tflg = 0,jOflg = 0,shutFlg = 0,sflg=0,BFLG1=0,BFLG2=0,bFlg3=0;
int16 BttVolt,DelayTime,DTT=2400,Ltime=0,dt,chrgCounter=0,d,sCounter = 0,shutcounter=0,bcounter=0,blCounter=0;
INT8 BUZZFLG = 0;
void SetBttVolt(void);
void WapdaCheck(void);
void doWapdaAbsent(void);
void doWapdaPresent(void);
void SetDelayTime(void);
void doShutDown(void);
#int_TIMER1
void  TIMER1_isr(void)
 scounter++;
 d++;
 if((WapdaFlg==0) && (FLgUps==1)){ // WAPDA IS ABSENT BUT UPS IS WORKING DUE TO BATT VOLTAGE ABOVE 2.0
//   printf("%ld,%ld\r",ltime,dtt);
   if (LTime==0)
      LTime = 1;
      dt = dTT - 3000;
         if(dTT >= 3000){
            output_high(PUSH);
            delay_us(dt);
      output_low(PUSH);
      delay_us(Ltime);
      delay_us(100);  //dead gap at end of c2
      output_low(PULL);
      delay_us(Ltime);
      output_high(PULL);
      delay_us(2000); // fix 5ms high time
      delay_us(dT);
      output_low(PULL);
      delay_us(Ltime);
      delay_us(Ltime);
      output_high(PUSH);
 else{
      output_low(PUSH);
      output_low(PULL);
 set_timer1(63533); // fix 3ms delay
 IF(BUZZFLG>0)
   BUZZFLG--;
   OUTPUT_HIGH(BUZZER);
   bflg1 = 1;
   bflg2 =1;
   bflg3 = 1;
 }ELSE{
   OUTPUT_LOW(BUZZER);
   bcounter++;
   //printf("%ld\r",bcounter);
   int16 i=0;
   Flg = 0;
   FlgUps=0;
   WapdaFlg = 0;
   set_tris_a(0b100011);
   output_c(0);
   output_low(pin_a2);
   output_low(pin_a3);
   output_low(pin_a4);
   setup_adc_ports(sAN0|sAN1|VSS_VDD);
   setup_adc(ADC_CLOCK_DIV_32);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
   output_high(LEDWAPDA);
  // output_high(UPSled);
   //output_low(pin_a4);
   If(!input(WAPDAIN)){
         wapdaFlg = 1;
         Flgups = 0;
   }else{
         wapdaFlg = 0;
         Flgups = 1;
         SetDelayTime();
         while(d<100){
            SetDelayTime();
/*   for(i=10;i>1;i--){
      SetBttVolt();
      WapdaCheck();
      if (WapdaFlg){
         doWapdaPresent();
      }else{//if waPDA IS ABSENT
          doWapdaAbsent();
      delay_ms(1);
      Ltime = 2400;
      dTT = 5000;
    while (1){
      SetBttVolt();
      WapdaCheck();
       if(shutFlg == 0){
         if (WapdaFlg){
            doWapdaPresent();
            bflg1=0;
            //bflg3=0;
            doWapdaAbsent();
            bflg2=0;
       }else
         doShutDown();
         SetDelayTime();
   }//while
void SetDelayTime(){
      int16 t;
      INT16 Tempf;
      set_adc_channel(MAINCH);
      delay_us(20);
      t = read_adc();
      If (t <= 327){        // 1.0v for 9.8ms pulse
         DelayTime = 9800;
      }Else if (t >= 491){   // 2.0v for 3.0ms pulse
            DelayTime = 3000;
      }Else{
          t = 491 - t;
          TempF = t * 41; // conversion for 245 to 6800ms
          DelayTime = 3000 + TempF;
     DTT = DELAYTIME;
     LTIME = (9800 - DTT)/2;
   //  printf("%ld\r",dtt);
void WapdaCheck(){
     If(!input(WAPDAIN)){     //        'Wapda present
         while( d < 100 && !input(WAPDAIN)){
         //       printf("%ld\r",d);
        if(d>=100){
            WapdaFlg = 1;
            flg = 0;
            output_low(PUSH);
            output_low(PULL);
            output_Low(BttLowInd);
            output_LOW(LedWapda);
            shutFlg = 0;
            d=101;
//            printf("-----------0\r");
     }Else{
        WapdaFlg = 0;
        d=0;
        output_Low(RelayBttChrg);
        output_HIGH(LedWapda);
        output_low(FAN);
//        printf("-----------1\r");
 void SetBttVolt(){
      set_adc_channel( BTTCH );
      delay_us(20);
      BttVolt = read_adc();
  void doWapdaAbsent(){
      if(bflg1==0)
         buzzflg = 500;
      jOflg = 0;
      chrgcounter=0;
      output_LOW(UPSLED);
      output_high(FAN);
      chrgflg = 0;
      chrgCounter=0;
      FlgUps = 1;
//      printf("-----------b\r");
       If (BttVolt < 368){    //        'Battery is too low. At 10v (on ADC 1.8) shutdown UPS
         shutcounter++;
         if(shutcounter>100){
            shutcounter=0;
            output_HIGH(UPSLED);
            output_low(buzzer);
            shutFlg = 1;
       }else if(BttVolt < 409 ){    // '21v (on ADC 2.1v) Low battery indication
         blcounter++;
         if(blcounter>100){
            blcounter=0;
            output_high(BttLowInd);
            shutcounter=0;
            if(bflg3==0)
               buzzflg = 500;
               bcounter = 0;
            }else if(bcounter > 1000)
               bcounter=0;
               bflg3=0;
       }else{
         shutcounter=0;
         blcounter=0;
  void doWapdaPresent(){
      if(bflg2==0)
         buzzflg = 250;
         output_High(UPSLED);
//         printf("-----------c,%ld\r",bttvolt);
         If (BttVolt > 572){ //         'Voltage exceeds 27v (on ADC 2.7v) then  cut charging
            output_low(FAN);
            chrgflg==0;
         Else If (BttVolt < 491 && joFlg ==1 ){     //   'Voltage 12v when charging starts
               output_High(RelayBttChrg);
               output_high(FAN);
               output_low(BttLowInd);
               chrgflg=1;
         }Else If (BttVolt < 572 && joFlg ==0 ){     //   'Voltage 26v when charging starts
            chrgCounter++;
//            printf("**chc = %ld\r",chrgCounter);
            if(chrgflg==0 && chrgCounter>10000){
               output_high(FAN);
               chrgFlg=1;
               jOflg=1;
               chrgcounter=10001;
  void doShutDown(){
      FLgUps=0;
      jOflg = 0;
      chrgcounter=0;
      shutcounter=0;
      if(sflg == 0 && scounter > 100)
         output_high(bttLowInd);
         scounter = 0;
         sflg = 1;
         //printf("-----------\r");
      }else if(sflg == 1 && scounter > 100){
         output_low(bttLowInd);
         scounter = 0;
         sflg = 0;
//         printf("***************\r");
The above is the complete code for a ups opreation.
But my questin was bit general in a sense that may be
1 - I dont know how to use internall oscilator or How to calibrate it.
2 - If i use Timer1 interrupt to generate fixed interval interrupt for generating 50Hz flip folp pulses. Is it possible in 16f676 with internall oscilator or not.
Because
3- I have used the same code in 16f877a with external crystal oscialator and results are seme with evey chip, But this is not the case while is use 16f676 and internall oscillator. So where i am doing wrong.[/quote]
mskala
PostPosted: Tue Jun 10, 2008 7:23 am     Reply with quote
Without looking at your code, which also is incomplete since there are no fuse assignments, my comment is really what is your expectation? I don't know what you mean by every chip is different. The internal oscillator is only calibrated to +/- 1%, which is hundreds of times worse than you can do with external. Are you seeing 2% difference in frequency? There is a calibration register that you can use if necessary, but I still doubt it can match external, especially over temperature.
