LCD 16 * 2 without driver help !!
psypersky
PostPosted: Wed Jul 15, 2009 12:26 pm     Reply with quote
Hi, my name is Ruben
I want to use an LCD 16*2 without driver(without circuitry), connected directly to my 16f877A
here is the LCD:
http://www.allelectronics.com/make-a-store/item/LCD-94/2.68-X-0.8-LCD-NO-CIRCUITRY/-/1.html
Does anyone knows how?? An Engineer told me that is possible.
PostPosted: Wed Jul 15, 2009 1:08 pm     Reply with quote
You would have to duplicate everything in this chip:
http://www.sparkfun.com/datasheets/LCD/HD44780.pdf
Just buy the normal parallel-interface LCD.
graphic or character mode?
PostPosted: Wed Jul 15, 2009 2:14 pm     Reply with quote
in the 16F family - the ONLY parts that offer a glimmer of hope for you
are to be found in the datasheet for
PIC16F913/914/916/917/946
best 'o luck
psypersky
Cost
I want to do this because an LCD without driver cost about 0.1$/0.2$ DLLS
and this circuit is for an extensive production.
Do you think it's extremely difficult?
PostPosted: Wed Jul 15, 2009 2:16 pm     Reply with quote
Those are for segmented LCDs, not dot-matrix LCDs.
mkuang
Re: Cost
PostPosted: Wed Jul 15, 2009 2:21 pm     Reply with quote
Not difficult, just impossible. There isn't a snowball's chance in hell you will be able to duplicate all the functionality in the driver chip PCM programmer linked to.
PostPosted: Wed Jul 15, 2009 2:54 pm     Reply with quote
I did it some time ago. However the board involved, had a huge amount of logic involved, so I had a FPGA. I generated a small addressable RAM area using this, and the required dot control/timings in the same chip. I think it worked out at about 300 gates....
Basically, unless you have something similar, you can't do this. It is worth considering, if you are in a similar position, with enough external logic to warrant the gate array, but otherwise it'll cost more to control the LCD, than the controller itself.
However, if you only need basic number displays, without dot matrix characters, then much cheaper, and gives a clearer display, to switch to a segmented display, and a PIC that drives these....
