crystalfontz CFAG12864BTMIV
omardhouib
PostPosted: Tue May 20, 2008 3:12 am     Reply with quote
Hi everyone
I am new in PIC technology and I try to interface a GLCD (128 x 64) by crystalfontz CFAG12864BTMIV with PIC18f4620. The GLCD is not working. No text or pixels or whatever is in the program is being displayed.
This LCD has a backlight.
My compiler is PCWHD 4.065 and I simulate my code with ISIS 7.1 SP2. The simulation with ISIS it’s Ok but in the reality I have no chance. Here are the connections:
1= 5V
2= GND
Pin 1
_|_
| |-------------- connect with pin 3= Pot 10K ohm
| Pin 18
4= RD0
5=RD1
6=RD2
7=RD3
8=RD4
9=RD5
10=RD6
11=RD7
12= CS1=RB0
13=CS2=RB1
14=RST=RC0
15= R/W=RB7
16 = D/I=RB2
17= E = RB5
18 = VEE = POT
R= 25 ohm
19= ----\/\/\/\/\/\/\-- 5V
20= GND
Data sheet of The LCD;
http://www.crystalfontz.com/products/12864b/datasheets/277/CFAG12864BTMIV.pdf
GLCD.C
Code removed by forum moderater. Ref. forum policy #10:
10. Don't post the CCS example code or drivers, or ask for such code and drivers.
Hello.c
#include <18f4620.h>
#DEVICE *=16 CCSICD=TRUE
#fuses HS,NOWDT,NOPROTECT
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7,PARITY=N,BITS =8)
#INCLUDE <glcd.c>
  char v[]="Hello";
   glcd_init(on);
      while(true)
 glcd_text57(20,20,v,2,on);
 glcd_pixel(10,10,on) ;
Can anybody help me please……
bwhiten
Working driver
PostPosted: Tue May 20, 2008 6:50 am     Reply with quote
It appears you may have some #define statments missing or the code uses a different method. Here is a driver I modified slightly from another CCS driver that is working fine with that LCD. You will also need to include <graphics.c> in your program.
////                           CFAG12864B.c                          ////
//// File contains drivers for using a CrystalFontz CFAG12864B with  ////
//// a KS0108 controller. The CFAG12864B is 128 by 64 pixels.        ////
//// The driver treats the upper left pixel as (0,0).                ////
//// Use #define FAST_GLCD if the target chip has at least 1k of RAM ////
//// to decrease the time it takes to update the display.            ////
//// glcd_update() must then be called to update the display after   ////
//// changing the pixel information.                                 ////
//// See ex_glcd.c for suggested usage.                              ////
//// See KS0108.c for controlling a single 64 by 64 display          ////
//// LCD Pin connections:                                            ////
//// (These can be changed as needed in the following defines).      ////
////  * 1: VSS is connected to GND                                   ////
////  * 2: VDD is connected to +5V                                   ////
////  * 3: V0  - LCD operating voltage (Constrast adjustment)        ////
////  * 4: D/I - Data or Instruction is connected to B4              ////
////  * 5: R/W - Read or Write is connected to C6                    ////
////  * 6: Enable is connected to C7                                 ////
////  *7-14: Data Bus 0 to 7 is connected to port D0 to D7           ////
////  *15: Chip Select 1 is connected to E0                          ////
////  *16: Chip Select 2 is connected to E1                          ////
////  *17: Reset is connected to E2                                  ////
////  *18: Negative voltage is also connected                        ////
////  *19: Positive voltage for LED is connected to current limit +5V////
////  *20: Negavtive voltage for LED is connected to switched GND    ////
////  glcd_init(mode)                                                ////
////     * Must be called before any other function.                 ////
////       - mode can be ON or OFF to turn the LCD on or off         ////
////  glcd_pixel(x,y,color)                                          ////
////     * Sets the pixel to the given color.                        ////
////       - color can be ON or OFF                                  ////
////  glcd_fillScreen(color)                                         ////
////     * Fills the entire LCD with the given color.                ////
////  glcd_update()                                                  ////
////     * Write the display data stored in RAM to the LCD           ////
////     * Only available if FAST_GLCD is defined                    ////
////        (C) Copyright 1996, 2004 Custom Computer Services        ////
//// This source code may only be used by licensed users of the CCS  ////
//// C compiler.  This source code may only be distributed to other  ////
//// licensed users of the CCS C compiler.  No other use,            ////
//// reproduction or distribution is permitted without written       ////
//// permission.  Derivative programs created using this software    ////
//// in object code form are not restricted in any way.              ////
#ifndef CFAG12864B
#define CFAG12864B
#ifndef GLCD_WIDTH
#define GLCD_WIDTH   128
#endif
#ifndef GLCD_CS1
#define GLCD_CS1     PIN_E0   // Chip Selection 1
#endif
#ifndef GLCD_CS2
#define GLCD_CS2     PIN_E1   // Chip Selection 2
#endif
#ifndef GLCD_DI
#define GLCD_DI      PIN_B4   // Data or Instruction input
#endif
#ifndef GLCD_RW
#define GLCD_RW      PIN_C6   // Read/Write
#endif
#ifndef GLCD_E
#define GLCD_E       PIN_C7   // Enable
#endif
#ifndef GLCD_RST
#define GLCD_RST     PIN_E2   // Reset
#endif
#define GLCD_LEFT    1
#define GLCD_RIGHT   0
#ifndef ON
#define ON           1
#endif
#ifndef OFF
#define OFF          0
#endif
// Function Prototypes
void glcd_init(int1 mode);
void glcd_pixel(int8 x, int8 y, int1 color);
void glcd_fillScreen(int1 color);
void glcd_writeByte(int1 side, BYTE data);
BYTE glcd_readByte(int1 side);
void glcd_update();
#ifdef FAST_GLCD
struct
   int8 left[512];
   int8 right[512];
} displayData;
#endif
// Purpose:       Initialize the LCD.
//                Call before using any other LCD function.
// Inputs:        OFF - Turns the LCD off
//                ON  - Turns the LCD on
   // Initialze some pins
   output_high(GLCD_RST);
   output_low(GLCD_E);
   output_low(GLCD_CS1);
   output_low(GLCD_CS2);
   output_low(GLCD_DI);                 // Set for instruction
   glcd_writeByte(GLCD_LEFT,  0xC0);    // Specify first RAM line at the top
   glcd_writeByte(GLCD_RIGHT, 0xC0);    //   of the screen
   glcd_writeByte(GLCD_LEFT,  0x40);    // Set the column address to 0
   glcd_writeByte(GLCD_RIGHT, 0x40);
   glcd_writeByte(GLCD_LEFT,  0xB8);    // Set the page address to 0
   glcd_writeByte(GLCD_RIGHT, 0xB8);
   if(mode == ON)
      glcd_writeByte(GLCD_LEFT,  0x3F); // Turn the display on
      glcd_writeByte(GLCD_RIGHT, 0x3F);
      glcd_writeByte(GLCD_LEFT,  0x3E); // Turn the display off
      glcd_writeByte(GLCD_RIGHT, 0x3E);
   glcd_fillScreen(OFF);                // Clear the display
   #ifdef FAST_GLCD
   glcd_update();
   #endif
// Purpose:    Update the LCD with data from the display arrays
#ifdef FAST_GLCD
void glcd_update()
   int8 i, j;
   int8 *p1, *p2;
   p1 = displayData.left;
   p2 = displayData.right;
   // Loop through the vertical pages
   for(i = 0; i < 8; ++i)
      glcd_writeByte(GLCD_LEFT, 0x40);          // Set horizontal address to 0
      glcd_writeByte(GLCD_LEFT, i | 0xB8);      // Set page address
      glcd_writeByte(GLCD_RIGHT, i | 0xB8);
      output_high(GLCD_DI);                     // Set for data
      // Loop through the horizontal sections
      for(j = 0; j < 64; ++j)
         glcd_writeByte(GLCD_LEFT, *p1++);      // Turn pixels on or off
         glcd_writeByte(GLCD_RIGHT, *p2++);     // Turn pixels on or off
#endif
// Purpose:    Turn a pixel on a graphic LCD on or off
// Inputs:     1) x - the x coordinate of the pixel
//             2) y - the y coordinate of the pixel
//             3) color - ON or OFF
#ifdef FAST_GLCD
   int8* p;
   int16 temp;
   temp =  y/8;
   temp *= 64;
   temp += x;
   if(x > 63)
      p = displayData.right + temp - 64;
      p = displayData.left + temp;
   if(color)
      bit_set(*p, y%8);
      bit_clear(*p, y%8);
#else
   BYTE data;
   int1 side = GLCD_LEFT;  // Stores which chip to use on the LCD
   if(x > 63)              // Check for first or second display area
      x -= 64;
      side = GLCD_RIGHT;
   bit_clear(x,7);                              // Clear the MSB. Part of an instruction code
   bit_set(x,6);                                // Set bit 6. Also part of an instruction code
   glcd_writeByte(side, x);                     // Set the horizontal address
   glcd_writeByte(side, (y/8 & 0xBF) | 0xB8);   // Set the vertical page address
   glcd_readByte(side);                         // Need two reads to get data
   data = glcd_readByte(side);                  //  at new address
   if(color == ON)
      bit_set(data, y%8);        // Turn the pixel on
   else                          // or
      bit_clear(data, y%8);      // turn the pixel off
   glcd_writeByte(side, data);   // Write the pixel data
#endif
// Purpose:    Fill the LCD screen with the passed in color
// Inputs:     ON  - turn all the pixels on
//             OFF - turn all the pixels off
#ifdef FAST_GLCD
   int8  data;
   int8  *p1, *p2;
   int16 i;
   data = 0xFF * color;
   for(i=0; i<512; ++i)
      *p1++ = data;
      *p2++ = data;
#else
   int8 i, j;
      glcd_writeByte(GLCD_LEFT, 0b01000000);    // Set horizontal address to 0
      glcd_writeByte(GLCD_RIGHT, 0b01000000);
      glcd_writeByte(GLCD_LEFT, i | 0b10111000);// Set page address
      glcd_writeByte(GLCD_RIGHT, i | 0b10111000);
         glcd_writeByte(GLCD_LEFT, 0xFF*color);  // Turn pixels on or off
         glcd_writeByte(GLCD_RIGHT, 0xFF*color); // Turn pixels on or off
#endif
// Purpose:    Write a byte of data to the specified chip
// Inputs:     1) chipSelect - which chip to write the data to
//             2) data - the byte of data to write
   if(side)                   // Choose which side to write to
      output_high(GLCD_CS2);
      output_high(GLCD_CS1);
   output_low(GLCD_RW);       // Set for writing
   output_d(data);            // Put the data on the port
   delay_cycles(1);
   output_high(GLCD_E);       // Pulse the enable pin
   delay_cycles(5);
   output_low(GLCD_E);
   output_low(GLCD_CS1);      // Reset the chip select lines
// Purpose:    Reads a byte of data from the specified chip
// Ouputs:     A byte of data read from the chip
   BYTE data;                 // Stores the data read from the LCD
   set_tris_d(0xFF);          // Set port d to input
   output_high(GLCD_RW);      // Set for reading
   delay_cycles(1);
   delay_cycles(4);
   data = input_d();          // Get the data from the display's output register
   output_low(GLCD_E);
   return data;               // Return the read data
#endif
omardhouib
CFAG12864B
PostPosted: Thu May 22, 2008 1:11 am     Reply with quote
Thank you for your help bwhiten.
I try your driver. the simulation with ISIS it's OK. but in the reality its not working.just a blue light in the LCD
my connection is :
LCD = Fonction = PIC
12 = CS1 = RB0
13 = CS2 = RB1
14 = RST = RC0
15 = R/W = RB7
16 = D/I = RB2
17 = E = RB5
so I change the some lines in your driver but its not working again...
#ifndef GLCD_CS1
#define GLCD_CS1     PIN_B0   // I changed the PIN_B0 by the PIN_E0
#endif
#ifndef GLCD_CS2
#define GLCD_CS2     PIN_B1   // I changed the PIN_E1 by the PIN_B1
#endif
#ifndef GLCD_DI
#define GLCD_DI      PIN_B2   // I changed the PIN_B4 by the PIN_B2
#endif
#ifndef GLCD_RW
#define GLCD_RW      PIN_B7   // I changed the PIN_C0 by the PIN_B7
#endif
#ifndef GLCD_E
#define GLCD_E       PIN_B5   // I changed the PIN_C7 by the PIN_B5
#endif
#ifndef GLCD_RST
#define GLCD_RST     PIN_C0   // I changed the PIN_E2 by the PIN_C0
#endif
what do you say......
bwhiten
Check that you have correct include file
PostPosted: Thu May 22, 2008 6:42 am     Reply with quote
Post your newest version of Hello.c
omardhouib
hello.c
PostPosted: Sat May 24, 2008 2:09 am     Reply with quote
hello.c
#ROM 0x7F38 = {0x9000}
#ROM 0x7F3A = {0xEF00}
#ROM 0x7F3C = {0xF000}
#fuses XT,NOWDT,NOPROTECT
#include <CFAG12864B.c>
//#include <HDM64GS12o.c>
#include <graphicso.c>
   char  ABC[] = "hello";
   glcd_init(on);                               // Must initialize the LCD
   for(;;)
 glcd_text57(10, 10, ABC,1, ON);
bwhiten
PostPosted: Sat May 24, 2008 10:42 am     Reply with quote
That looks correct enough. I used the TRIS registers to set up the input/output pins so you may want to try that as well.
The voltage at pin 3 should be initially adjusted to -3.0 Volts, when referenced to ground. If this is not close the screen will "appear" to be blank.
Make sure that the pot is adjusted for that voltage first.
