18F452 & FLASH memory && write_program_memory
nicolebarge23
PostPosted: Fri Jul 18, 2008 7:31 am     Reply with quote
Hello !
I work with a 18f452 and i want store datas in the program memory. I use the write_program_memory(adr, data, x) to write in the FLASH.
In simulation, everything is good !!!! all my datas are stored in the flash. I use PROTEUS to simulate my 18f452 and the electrical draw.
But, when I fill my "true" 18f452 with my software, the datas aren't stored in the flash. I don't understand why there is a difference between the simulation and the experience ????
I can't even make work the samples of CCS about the write_program_memory function.
I would like to know if it is because the software or because any initialisation that i do.
I post my soft to see what i did !
/*   Enregistrement   :    Fonction permettant d'enregistrer les nouvelles Trames lorsque    */
/*                  l'on enclenche le mode learning.                        */
/*                  Utilisation des listes chainées pour ne pas allouer trop       */
/*                  d'espace mémoire                                     */
/*                  Enregistrement de Liste Horizontale pour les Sorties (IO) puis   */
/*                  enregistrement de Liste Verticale pour les Trames            */
byte Enregistrement(char buffer[100])
   long int ionumber,iodatanext,datanext,adresse,ionext;
   char   database[29];
   output_toggle(PIN_A0);
   //on initialise au début de la mémoire afin d'etre sur de tout lire
   FlashStartAddress = FLASH_DATA_START ;
   read_program_memory(FlashStartAddress,   &ionumber, 1 );                        //Lecture de ionumber
   //Initialisation si aucune trame n'a jamais été enregistrée
   //            IOSTART
   if( ionumber == 255  )
      strcpy(database, buffer );                                          //copie du buffer dans database
      adresse = FlashStartAddress+5;                                       //adresse du pointeur de Database
      ionext = 0;
      datanext = 0;
      write_program_memory( FlashStartAddress,    &IO         ,1   );               //enregistrement de  p_IO_Next->IONumber
      write_program_memory( FlashStartAddress+1,    &adresse   ,2   );               //enregistrement de p_IO_Next->DataNext
//      write_program_memory( FlashStartAddress+3,    &ionext      ,2   );               //enregistrement de p_IO_Next->IONext
      write_program_memory( FlashStartAddress+5,    database   ,29   );               //enregistrement de p_Data_Next->Database
//      write_program_memory( FlashStartAddress+34, &datanext   ,2   );               //enregistrement de p_Data_Start->DataNext
      if ( FlashAddress < FlashStartAddress )      FlashAddress = FlashStartAddress;
      puts("enregistre la trame suivante :");
      puts(database);
      printf("sur la sortie : %d\r",IO);
   //Si il existe deja une sortie initiale qui a été enregistrée
   else if ( 0 < ionumber < 17 )
      // On se place au début de la chaine de pointeur de sortie
      //               p_IO_Next = p_IO_Start
      read_program_memory( FlashStartAddress      , &ionumber      ,1   );            //lecture de  p_IO_Next->IONumber
      read_program_memory( FlashStartAddress+1   , &iodatanext   ,2   );            //lecture de p_IO_Next->DataNext
      read_program_memory( FlashStartAddress+3   , &ionext      ,2   );            //lecture de p_IO_Next->IONext
      read_program_memory( FlashStartAddress+5   , database      ,29   );            //lecture de p_Data_Next->Database
      read_program_memory( FlashStartAddress+34   , &datanext      ,2   );            //lecture de p_Data_Start->DataNext
      // on parcours tous les IO juska 16 inclus
      while(ionext!=65535 && ionumber!=IO)
         //            p_IO_Next = p_IO_Next->IONext ;                        //on décale d'une sortie
         FlashStartAddress = ionext;
         read_program_memory( FlashStartAddress+34   , &datanext      ,2   );         //lecture de p_Data_Next->DataNext
      //Creation d'une nouvelle sortie
      if ( ionumber != IO )
         adresse = FlashAddress+64 ;
         write_program_memory( FlashStartAddress+3   , &adresse      ,2   );         //enregistrement de p_IO_Next->IONext
         FlashStartAddress=adresse;
         ionext = 0;
         datanext = 0;
         puts(database);
      //Creation nouvelle Trame
      // On se place sur la sortie qui nous interesse pour rajouter une trame
      else if ( ionumber == IO )
         while ( datanext != 65535 && strcmp(database,buffer) != 0)
            FlashStartAddress = datanext;
         //Comparaison entre buffer (trame entrante et database (trame existante)
         if ( strcmp(database,buffer) == 0 )                                 // la trame a deja ete enregistree
            puts("la trame suivante existe deja :");
            puts(dataBase);
            return 0;
         if ( datanext == 65535 )
            //Creation nouvelle trame associée à la sortie
            adresse = FlashAddress + 64;
            write_program_memory(FlashStartAddress+34   , &adresse   ,2 );
            adresse+=5;
            strcpy(database,buffer);
            write_program_memory( FlashStartAddress      , &IO         ,1   );            //enregistrement de  p_IO_Next->IONumber
            write_program_memory( FlashStartAddress+1   , &adresse      ,2   );            //enregistrement de p_IO_Next->DataNext
//            write_program_memory( FlashStartAddress+3   , &ionext      ,2   );            //enregistrement de p_IO_Next->IONext
            write_program_memory( FlashStartAddress+5   , database      ,29   );            //enregistrement de p_Data_Next->Database
//            write_program_memory( FlashStartAddress+34   , &datanext      ,2   );            //enregistrement de p_Data_Start->DataNext
            puts("enregistre une nouvelle trame  :");
            puts(database);
            printf("sur la sortie : %i\r",IO);
[/quote]
