16F88 High Current Sleep mode
ivanperino
PostPosted: Wed May 21, 2008 5:48 pm     Reply with quote
HI, I have found a trouble I cant solve. I need some help from you.
I am working on PIC16F88 which does not "sleep" in a correct way. A high current flows from source to PIC when it is in sleep mode. At least 250uA go through uAmpmeter when it is sleeping. The code I have tried is what follows.
#include <C:\Archivos de programa\CCS4\Devices\16F88.h>
#fuses NOWDT,INTRC_IO, PUT, NOBROWNOUT, NOLVP, NOWRT, NOPROTECT, MCLR
#use delay(clock=8000000)
#define led pin_b3
#bit TMR1H_b7 = 0x0F.7
#int_timer1
void reloj(){
   TMR1H_b7 = 1; //32768
void main(){
   setup_timer_1(T1_EXTERNAL|T1_CLK_OUT|T1_DIV_BY_1);
   while(TRUE){
      output_bit(led,0);
      output_bit(led,1);
      sleep();
The LED goes up only when it is awake. It is away for 100mS and its consumption is about 2mA because LED.
Timer 1 is being swingig by a 32khz xtal, If I take the xtal off, PIC never awake and consumption downs to 90uA which is still high! datasheet displays a maximun of 1.7uA in sleep mode
Please! I know many people has past by this! thank you a lot!
Ivan Perino
PostPosted: Wed May 21, 2008 5:55 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=23376
