16F690 problem
rudy
View user's profile Send private message Send e-mail MSN Messenger
16F690 problem
PostPosted: Wed May 21, 2008 6:39 pm     Reply with quote
Hi there. Why I can't compile my routine with 16F690? I'm starting with a simple code like this:
#include <16F690.H>
#fuses INTRC_IO, NOWDT, NOPROTECT, BROWNOUT, PUT
the output is this:
*** Error 125 "C:\ARQUIV~1\PICC\devices\16F690.H" Line 233(9,14): Duplicate #define
Never saw this before, please help.
PostPosted: Wed May 21, 2008 7:18 pm     Reply with quote
Post your compiler version.
rudy
PostPosted: Wed May 21, 2008 7:24 pm     Reply with quote
yes.
is
IDE VERSION 3.225
PCB, PCM AND PCH 3.225
PostPosted: Wed May 21, 2008 7:55 pm     Reply with quote
The 16F690.H file is incorrect in that version. It's unfinished.
Delete the #define statements in the comparator section and put
in the following code instead. Also, there's no guarantee that
the comparator functions work in that version. I didn't test them.
But at least you won't get that error message.
#define NC_NC_NC_NC  0x00
#define CP1_A1_A0  0x80
#define CP1_C1_A0  0x81
#define CP1_C2_A0  0x82
#define CP1_C3_A0  0x83
#define CP1_A1_VR  0x84
#define CP1_C1_VR  0x85
#define CP1_C2_VR  0x86
#define CP1_C3_VR  0x87
#define CP1_OUT_ON_A2  0x20
#define CP1_INVERT  0x10
// Or the following with the above
#define CP2_A1_C0  0x8000
#define CP2_C1_C0  0x8100
#define CP2_C2_C0  0x8200
#define CP2_C3_C0  0x8300
#define CP2_A1_VR  0x8400
#define CP2_C1_VR  0x8500
#define CP2_C2_VR  0x8600
#define CP2_C3_VR  0x8700
#define CP2_OUT_ON_C4  0x2000
#define CP2_INVERT  0x1000
// Optionally Or the following with the above
#define COMP_C1_LATCHED        0x300000
#define COMP_T1_SYNC          0x1000000
#define COMP_T1_GATE          0x2000000
#bit C1OUT = 0x11B.7
#bit C2OUT = 0x11B.6
rudy
PostPosted: Wed May 21, 2008 7:58 pm     Reply with quote
Great.....
thank you very much.
