		| Author | Message |
		| julien lochen
				| "Expecting an opcode mnemonic   banksel" |
				|  Posted: Fri May 16, 2008 7:51 am |   |
				| Hello,
 I work with MPLAB and CCS V4.
 in my C program, I inserted a function in ASM between the keywords "#ASM" and "#ENDASM".
 It works but  when I use the opcode "banksel" I have "Expecting an opcode mnemonic   banksel".
 source files: main.c
 header files: 16F877A.h
 object files: none
 other files: main.SYM, main.TRE
 main.c:
 #include <16F877A.h>
 #define duree 1000000000
 void tempo(unsigned int count);
 #ASM
 banksel PORTB
 MOVLW 0xFF
 MOVWF PORTB
 banksel TRISB
 MOVLW 0x00
 MOVWF TRISB
 #ENDASM
 void tempo(unsigned int compte)
 while(compte--);
 thanks, julien lochen
		| Ttelmah Guest
				|  Posted: Fri May 16, 2008 7:59 am |   |
				| You don't need to use banksel. The CCS 'assembler', doesn't work like a full/normal assembler. Instead it is quite smart. If you tell it:
 #ASM
 MOVLW 0xFF
 MOVWF PORTB
 MOVLW 0x00
 MOVWF TRISB
 #ENDASM
 It will _automatically_ perform the bank selection operation as needed.
 In fact though, you don't even need to use assembler at all. The single line:
 output_b(0xFF);
 will automatically output 0xFF, on portB, and change the TRIS for you as well, without using any assembler.
		| julien lochen
				|  Posted: Fri May 16, 2008 8:11 am |   |
				| I stared coding in assembleur, I will continue using the C functions of CCS like output_b(X) ...
 I just want to reuse the assembleur allready written.
 I removed the line bankdel, now I have:
 "Error 12 "main.c" Line 22(1,6): Undefined identifier   PORTB"
 #ASM
 //banksel PORTB
 MOVLW 0xFF
 MOVWF PORTB
 //banksel TRISB
 MOVLW 0x00
 MOVWF TRISB
 #ENDASM
 while(compte--);
 thanks, julien
		| Ttelmah Guest
				|  Posted: Fri May 16, 2008 8:21 am |   |
				| You have to define things like PORTB, the assembler has no implicit 'knowledge' of things like this. Use the #byte directive to tell it where this register is (and the same for the TRIS). The normal assembler also doesn't have this knowledge, but there is normally a header file that defines all the standard registers etc., for you.
		| Guest
				|  Posted: Fri May 16, 2008 9:22 am |   |
				| ok, I declared PORTB and TRISB as byte, but they are not assigned as long as I do not use the opcode "banksel":
 #byte PORTB = 0xFF
 #byte TRISB = 0xFF
 #ASM
 //banksel PORTB
 MOVLW 0xFF
 MOVWF PORTB
 banksel PORTB
 //banksel TRISB
 MOVLW 0x00
 MOVWF TRISB
 #ENDASM
 while(compte--);
		| Ttelmah Guest
				|  Posted: Fri May 16, 2008 9:42 am |   |
				| AArgh!..... You have to declare them at their proper addresses. You have declared them at the _same_ (wrong) address. TRISB, is at 0x86, and PORTB is at 06.
 So:
  	  | Code: |  	  | #byte PORTB = 0x6
 #byte TRISB = 0x86
		| Ttelmah Guest
				|  Posted: Fri May 16, 2008 9:57 am |   |
				| As a comment, how is the code ever going to get to 'tempo'?... Just as a demo, of what you should have if you want to use the assembler:
 #byte TRISB = 0x86
 #ASM
 MOVLW 0xFF
 MOVWF PORTB
 MOVLW 0x00
 MOVWF TRISB
 #ENDASM
 Which if included in a program, and compiled, generates (in the .LST file):
  	  | Code: |  	  | .................... MOVLW 0xFF
 000C:  MOVLW  FF
 .................... MOVWF PORTB
 000D:  BCF    03.5
 000E:  MOVWF  06
 .................... MOVLW 0x00
 000F:  MOVLW  00
 .................... MOVWF TRISB
 0010:  BSF    03.5
 0011:  MOVWF  06
 Note the BCF 03.5, and the BSF 03.5, which are the bank selection operations.
		| julien lochen
				|  Posted: Fri May 16, 2008 11:06 am |   |
				| works fine, thank u veru much |  |
