18F4520 and Timer1 troubles
curt2go
PostPosted: Wed Jun 04, 2008 4:06 pm     Reply with quote
i am having some trouble getting timer1 to work with a 32,768 crystal on it. I have done this with other pics with success. Is there something weird with the pic and Timer1? Let me know if you have any thoughts.. TTY
PostPosted: Wed Jun 04, 2008 4:32 pm     Reply with quote
Here's a test program for an 18F452 with the Timer1 oscillator running
with an external 32.768KHz crystal on pins C0 and C1.
http://www.ccsinfo.com/forum/viewtopic.php?t=25824&start=7
Do you have the capacitors connected to the external crystal ?
The data sheet recommends 27pf.
curt2go
PostPosted: Wed Jun 04, 2008 5:38 pm     Reply with quote
the crystal is a 6pf. I even tried 15pf. I have used this crystal on other designs with 6 and it works fine. It is very weird. I am using the intrc_io for my main clock. Let me know if you have any other thoughts . Thanx
PostPosted: Wed Jun 04, 2008 6:13 pm     Reply with quote
You tried the program linked to by PCM Programmer?
What is your compiler version?
curt2go
PostPosted: Wed Jun 04, 2008 8:32 pm     Reply with quote
I am running the same program. 3.249..
drh
PostPosted: Thu Jun 05, 2008 8:02 am     Reply with quote
In section 12 on page 129 of the data sheet, DS39631A, there is information on using timer 1 as the system clock.
David
curt2go
PostPosted: Thu Jun 05, 2008 9:06 am     Reply with quote
i have tried everything.. New crystals . Caps up to 33pf. New processor. I tried the exact program that was posted. I can see the crystal oscillating at 32.768Khz on pin OSC2. But the timer 1 output no matter what is about 6 seconds.. Any ideas?
curt2go
PostPosted: Thu Jun 05, 2008 9:12 am     Reply with quote
i am totally retarded.. I have the crystal on the wrong pins.. I had them on the oscillator pins the the timer1 pins.. AHHHHHHHHHHHHHHHHHHH. TTY
mskala
PostPosted: Thu Jun 05, 2008 9:48 am     Reply with quote
Unrelated to your real problem, but also 4520 is in the list of pics that have an errata for timer1 usage, so check that file on microchips web site.
