serial communication among three PICs
afede
PostPosted: Mon May 12, 2008 4:23 pm     Reply with quote
Hi;
I want to communicate 3 PICs. First pic will transmit data to second one. Then, second PIC will receive, merge this data with its own data and transmit result to third PIC...
First PIC will transmit by pin_c6. Second PIC'll receive by pin_c7 and transmit pin_c6. Third PIC'll receive by pin_c7...
for first PIC:
#use rs232 (baud=600, xmit=PIN_C6)
for second PIC:
#use rs232 (baud=600, rcv=PIN_C7)
and the third PIC:
But these use codes are not enough. How can i introduce these PICs to each other??
PostPosted: Mon May 12, 2008 4:51 pm     Reply with quote
When you put only one pin (C6 or C7) in the #use rs232() statement,
the compiler will generate code for a software UART on those pins.
That's not the best way.
It's better to use the hardware UART. To do that, you must specify
both hardware pins (C6 and C7) in the same statement. Example:
#use rs232 (baud=600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
