Difference with running code under the debugger
ZachR
PostPosted: Mon May 12, 2008 10:03 am     Reply with quote
I'm developing some code for a 18f4620 that uses software SPI (SPI_Xfer). The code works perfectly when run under the debugger (enable the debugger and press Run). However, if I program the chip to run standalone, I end up having errors in my SPI comms. My first thought was some kind of timing problem, but I've added delays everywhere I could think of and still having the same issue. Is there something obviously different when running the debugger.
Thanks,
Zach
Running ver 4.041
P.S. I would post the code, but there are some non-distributable portions.
Ken Johnson
PostPosted: Mon May 12, 2008 11:16 am     Reply with quote
watchdog timer?
gets me every time :(
Ken
