Is there a simple way of disabling an i/o pins?
kein
PostPosted: Fri May 09, 2008 9:45 pm     Reply with quote
I just wonder if an output or input pin can be disabled! I've a button connected to portB PIN_B4 and would like to disable it during adc reading since it control how adc is read.
When this button on portb is pressed, the adc interrupt is enabled and a buffer is filled. During this time, the button should not respond to it if someone presses it while the buffer is not full. I've tried to change to output while buffer is filling and back to an input But this does not work! any idea?
#int_AD
void  ADXL330AD_isr(void)
  if(data.Indx < MAX_SIZE)
    //ADXL330PIN_B4ASOUTPUT;
     set_tris_b(0x07);         // TRISB = 00000111; RB4,RB2,RB1 and RB0
    data.Buff [data.Indx] = (read_adc(ADC_READ_ONLY) - 0X266);
    data.Indx++;
if(data.Indx == MAX_SIZE)
    data.Storage_flg = 0;
    data.Analysis_flag = 1;
    data.Indx = 0;
    set_tris_b(0x17);         // TRISB = 00010111; RB4,RB2,RB1 and RB0
    disable_interrupts(INT_AD); // ADC OFF
in the main function I've initialized portB pin_b4 as input.
kein
Don't worry I got it
PostPosted: Fri May 09, 2008 11:18 pm     Reply with quote
Don't worry I got it! All I've to do is set the a flag and then check for the button and the flag.i.e.
int1 flag = 1;
newbutton = input(pin_B4);
if(newbutton !=oldbutton && flag)
 //to do....
flag = 0;
oldbutton =  newbutton;
