problem with coding
HTAluvBeBeo
problem with coding
PostPosted: Sun May 11, 2008 1:07 pm     Reply with quote
Thanh you so so much
PostPosted: Sun May 11, 2008 1:25 pm     Reply with quote
Post a complete little test program that shows the problem.
For example, here is a short program that tests passing a parameter
to the read_rtc() function. I can compile it, and it does not show an
error.
Make a similar (very short) program that shows your problem. Post it.
#include <16F877.H>
#byte portd = 0x08
#define sec 0
unsigned char read_rtc(unsigned char addr)
unsigned char data;
portd=addr;
return (data);
unsigned char tmp1;
tmp1 = read_rtc(sec);
