How to pass a pointer to a constant in ROM to a function?
Chris.Guest
PostPosted: Sat May 03, 2008 3:46 am     Reply with quote
I'm trying to pass this string:
unsigned char rom test[] = {"HELLO"}
to this function:
void demo(unsigned char *c)
But the compiler doesn't like this line:
demo(&test);
Is there any way to do this?
Chris
MartinSwoll
PostPosted: Sat May 03, 2008 4:14 am     Reply with quote
Same problem here...
PCH returns this error:
*** Error 112 "main.c" Line 62(1,1): Function used but nor defined: ... demo SCR=700
Martin
MartinSwoll
PostPosted: Sat May 03, 2008 4:15 am     Reply with quote
Sorry, forgot to post my version...
It's 4.065...
KU5D
PostPosted: Sat May 03, 2008 6:52 am     Reply with quote
Two separate problems.
For the first, instead of
demo(&test);
try this,
demo(test);
As for the second (Error 112), are you sure your function definition appears to your compiler before the function is called?
Confidence is the feeling you have right before you fully understand the situation...
PostPosted: Sat May 03, 2008 9:44 am     Reply with quote
The following program works. See the key points shown in bold below.
If you run it in MPLAB simulator and use the MPLAB "UART1" for output,
it displays this in the output window:
HELLO
#include <16F877.H>
#device PASS_STRINGS=IN_RAM
unsigned char const test[] = {"HELLO"};
void demo(unsigned char *ptr)
printf(ptr);
demo(test);
