		| Author | Message |
		| rajasekar
				| compiler problem |
				|  Posted: Fri May 02, 2008 11:17 am |   |
				|   I am using 16F684 with ICD in debugging mode. I am getting the following error.
 My code is
 int16 a,b;
 setup_adc(ADC_OFF);
 setup_timer_1(T1_DISABLED);
 setup_vref(FALSE);
 //   setup_oscillator(False);
 for(;;){
 a=563;
 b=500;
 if(a < b)a=0;
 else a =1;
 // TODO: USER CODE!!
 the if statement always considers "a & b " as characters and "a" becomes zero.......!!!!
 Am I missing any compiler option... Please advice....
 Thanks in advance
 hi
		| PCM programmer
				|  Posted: Fri May 02, 2008 11:31 am |   |
				|  	  | Quote: |  	  | the if statement always considers "a & b " as characters |
 There is no way that it considers them to be characters.  The compiler
 can't do that.   It can't magically turn a variable name into a character.
 The problem is caused by something else.   It's probably caused by
 some error that you are making in the operation of the compiler or the
 CCS debugger.
 I made the test program shown below, and ran it in the MPLAB simulator.
 I put a breakpoint on the delay_cycles() line and displayed 'a' in a Watch
 window.   I then pressed the F9 to run to the breakpoint, and the watch
 window showed the value of 'a' is 1.  I pressed F9 several more times
 to do it again, and the value is always 1.   I tested this with compiler
 version 4.071.
  	  | Code: |  	  | #include <16F684.H>
 #fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT
 #use delay(clock = 4000000)
 int16 a,b;
 setup_adc(ADC_OFF);
 setup_vref(FALSE);
 for(;;){
 a=563;
 b=500;
 if(a < b)a=0;
 else a =1;
 delay_cycles(1);
 | You cannot post new topics in this forum You cannot reply to topics in this forum
