Need help with sending temperature by GSM
bdurgaharikiran
PostPosted: Sat Feb 16, 2008 10:43 pm     Reply with quote
i had a program (c program)which will send sms (temperature) using a phone and pic 16F876A when we send get to that phone using another cell, it also switch on ac machine when send sms as acon and also acoff it switches off ac machine
In my program initially we set a value for temp.
Microcontroller sense temperature but does nothing until we send get.
On sending get, it will send sms as high temp or low then it will waits
further for commands.
When we send acon or acoff it does respective action but i want to
implement a control system in it when we set a value for temperature.
When temperature is less than the set value the program should send us
temperature is low and also the value to us via sms and it also should
make a pin in B or C high i.e output of that pin should be 5v.
When temperature is greater than the set value the program should send
us temperature is high and also the value to us via sms the program
should do nothing but wait for our command.
I'm sending my program.
In it already one of pin in B port is high please make a new pin high.
#include <16F876A.h>
#include <string.h>
#include <stdlib.h>
#fuses HS,NOWDT,PROTECT,brownout,put
#use rs232(baud=9600, xmit=PIN_B3, rcv=PIN_B2, stream=GSM)
int count = 0;
float tem = 0;
byte ch = 0;
byte data[95];    //For storing SMS
byte err[] =      { "ERR" };
byte read[] =     { "READ" };
byte acon[] =     { "acon" };
byte acoff[] =    { "acoff" };
byte gettmp[] =   { "get" };
byte settmp[] =   { "set" }; //set25
byte num[12] ;    //For Storing Incoming Phone Number
long setvalue = 25; //default Temperature
int flag = 0;
float read_temperature()
   int i;
   int value;
   tem = 0;
   for(i=0;i<20;i++)
     delay_ms(10);
     value = Read_ADC();
     tem = (tem + value)/2;
   tem = tem + 12; //add constant to get actual temperature
   return tem;
void call_num()
      delay_ms(2000);
      fprintf(GSM,"ATD%s;\r\n",num);
      delay_ms(9000);
      fprintf(GSM,"ATH\r\n");
      delay_ms(2000);
   float tmp_send = 0;
   int i = 0;
   int j = 0;
   char *ptr;
   long setvalue;
   SET_TRIS_B(0b00000100);
   SET_TRIS_C(0x00);  //Pin-4 for AC Relay Control
   OUTPUT_B(0x00);
   OUTPUT_C(0x00);
   //For Temperature Reading
   setup_port_a( ALL_ANALOG );
   setup_adc( ADC_CLOCK_INTERNAL );
   set_adc_channel(0);
   //Microcontroller Health check indicator start
   output_high(PIN_B7);
   output_low(PIN_B7);
   output_low(PIN_B7);
   //Health check end
     count = 0;   //reset data buffer count
     fprintf(GSM,"ATE0\r\n");  //Echo Off
     delay_ms(3000);
     fprintf(GSM,"AT+CMGF=1\r\n");  //Set to text format
     delay_ms(3000);
     fprintf(GSM,"AT+CPMS=\"ME\"\r\n"); //Preferred Message Store is Mobile phone
     delay_ms(5000);
     if(flag == 1)
           tmp_send = read_temperature();
           if(tmp_send > (setvalue+1))
               fprintf(GSM,"AT+CMGS=\"%s\"\r\n",num); //SMS to Number
               fprintf(GSM,"High Temperature : %f\r\n",tmp_send);
               fputc(0x1A,GSM); //^Z to send SMS
               delay_ms(30000);  //long wait for second check
               continue;
           else if(tmp_send < (setvalue-1))
               fprintf(GSM,"Low Temperature : %f\r\n",tmp_send);
               continue;
     fprintf(GSM,"AT+CMGR=1\r\n");  //Read SMS at location 1
     delay_ms(10);
         ch = fgetc(GSM);  //Read a character
         data[count] = ch;
         count++;
         if(ch == '\r')
         if(count > 93)
            count = 93;  //If SMS length exceeds override last byte
     data[count] = 0;  //end of string
     if(strstr(data,err))
       continue;   //If No Messages at location 1, continue
     //Message Available
     if(strstr(data,read))
       i = 0;
       //extract the number from SMS data
       while(data[i] != '9')
          i++;
          if(i > 250)  //for extra safety
       if((data[i] == '9') && (data[i+1] == '1'))
          i++;
          i++;
          for(j=0;j<10;j++)
             num[j] = data[i];  //num got the phone number
             i++;
          num[j] = 0;
          flag = 1;  //Got the destination phone number
    //delete the message to accommodate the new message
    fprintf(GSM,"AT+CMGD=1\r\n");
    delay_ms(3000);
     if(strstr(data,acon))
         output_high(PIN_C4);
         call_num();
     else if(strstr(data,acoff))
         output_low(PIN_C4);
         output_low(PIN_B7);
         call_num();
     else if(strstr(data,settmp))
         ptr = strtok(data, settmp);
         ptr = strtok(0, settmp);
         setvalue = strtoul(ptr,NULL,10);
         delay_ms(2000);
         fprintf(GSM,"Temperature Setting changed to: %Lu\r\n",setvalue);
         delay_ms(2000);
         delay_ms(30000);
     else if(strstr(data,gettmp))
         delay_ms(3000);
         fprintf(GSM,"Live Temperature is: %f\r\n",tmp_send);
         delay_ms(3000);
         delay_ms(30000);
         delay_ms(2000);
         fprintf(GSM,"Invalid Command Mr.%s We are from Eluru :-)\r\n",num);
         delay_ms(2000);
         fputc(0x1A,GSM);
         delay_ms(30000);
PostPosted: Mon Apr 07, 2008 5:23 pm     Reply with quote
is this code working?
dont you need to put #int_rda to read the sms?
pattousai
PostPosted: Tue Apr 08, 2008 5:13 am     Reply with quote
sorry to come with no help
but... i'm wondering... your code is base on at commands, isn't that right?
well, i don't know much of that stuff (almost nothing) and i think i will have to learn that, so, by any chance you have any tutorial, book or site to indicate?
thank you very much
PostPosted: Tue Apr 08, 2008 7:50 am     Reply with quote
AT-commands are based on the GSM standards but every manufacturer adds their own commands and limitations. Check your modem manufacturer's website for a command manual. If you can't find the command manual then post your modem type here and we might be able to provide you with a link.
pattousai
PostPosted: Tue Apr 08, 2008 11:12 am     Reply with quote
humm... actually, i want to use a simple cell phone, like nokia 2610.
those phones are compatible with AT-commands?
thanks again
PostPosted: Tue Apr 08, 2008 12:25 pm     Reply with quote
Most phones use AT-commands. Have a look at the Nokia developer site for more info: http://www.forum.nokia.com/
Here is a link to the specifications of your phone: http://www.forum.nokia.com/devices/2610
And a link to a page where you can download a description of the Nokia AT-commandset: http://www.forum.nokia.com/info/sw.nokia.com/id/95672052-6c77-488d-a055-acef77e4cdc5/AT_Command_Set_For_Nokia_GSM_And_WCDMA_Products_v1_2_en.pdf.html
elektrol
tc35 sms
PostPosted: Wed Apr 30, 2008 1:36 am     Reply with quote
hello boys, I have compile the code but it have a problem becouse the complier send this message:
Error 74 "tc35_5_seriale.c" Line 211(1,2): Not enough RAM for all variables
the problem is this line: byte data[95]; //For storing SMS
Why my compiler sends this error? please help me?
thanks
