CCS lcd.c driver question.
neddie
PostPosted: Tue Apr 29, 2008 2:39 am     Reply with quote
Hi to all.
I am a little confused about how the "lcd_putc" function works.
It is called for instance like this : lcd_putc("hello world");
The function accepts a 'char' an an argument.
Should it not receive a pointer to char?
I am trying to get this code to run on a different compiler (Codewarrior)
and it complains that it is receiving " signed char * " and it's expecting "signed char "
Is the CCS compiler handling this differently than normal?
My "C" is not that great , so I may be missing something here!!
Cheers
Rob
Here is a copy of the lcd_putc function.
void lcd_putc( char c)
   switch (c) {
     case '\f'   : lcd_send_byte(0,1);
                   delay_ms(2);
     case '\n'   : lcd_gotoxy(1,2);        break;
     case '\b'   : lcd_send_byte(0,0x10);  break;
     default     : lcd_send_byte(1,c);     break;
PostPosted: Tue Apr 29, 2008 8:56 am     Reply with quote
Yes, the CCS compiler is handling this different. From the manual:
A (non-standard) feature has been added to the compiler to help get around the problems created
by the fact that pointers cannot be created to constant strings. A function that has one CHAR
parameter will accept a constant string where it is called. The compiler will generate a loop that will
call the function once for each character in the string.
Example:
void lcd_putc(char c ) {
lcd_putc ("Hi There.");
neddie
PostPosted: Tue Apr 29, 2008 2:27 pm     Reply with quote
Thanks for the help. I was not aware of that limitation.
I have rewritten the function in the new compiler to accept
a pointer to a string , and it works great.
Thanks again.
Cheers
Rob
