Andrea Guest
Problem with #ORG |
Posted: Mon May 05, 2008 2:20 am |
Hi everyone,
I've got a problem with an #ORG instruction.
I'm trying to insert the CCS bootloader in my code program but...
Every time I reserve space in ROM using the #ORG directive, the space it's correctly reserved but, in the address 0x00000, where everything starts, there's not a jump to the main program but the compiler puts there the code of an interrupt.
This doesn't allow the machine to start properly.
I'm using the latest version of 4.069 and the microcontroller is the PIC18F6722.
Any idea?
Thanks |
Posted: Mon May 05, 2008 2:38 am |
Look at the bootloader examples. Look at the use of the #build instruction.
Posted: Mon May 05, 2008 2:54 am |
Ttelmah wrote: | Look at the bootloader examples. Look at the use of the #build instruction.
I've made in the same way but during compilation something goes wrong with the 0x00000 address. |
Matro Guest
Posted: Mon May 05, 2008 3:58 am |
Post a small compilable code that demonstrates the problem with all preprocessor directives and fuses.
Matro |
Posted: Mon May 05, 2008 4:16 am |
Matro wrote: | Post a small compilable code that demonstrates the problem with all preprocessor directives and fuses.
Matro |
Here is the main.h and following the bootloader directives
***********MAIN.H
#include <18F6722.h>
#device *=16
#device ICD=TRUE
#device adc=8
#OPT 9
#FUSES HS //High speed Osc (> 4mhz)
enabled
#FUSES CCP2C1
#FUSES WDT //Watch Dog Timer
#FUSES WDT32768 //Watch Dog Timer uses 1:32768 Postscale
#FUSES BORV27 //Brownout reset at 2.7V
#FUSES PUT //Power Up Timer
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES DEBUG //Debug mode for use with ICD
#FUSES NOWRTC //configuration registers write not protected
#FUSES NOLPT1OSC //Timer1 configured for higher power operation
#FUSES BBSIZ1K //1K words Boot Block size
#use delay(clock = 20000000, RESTART_WDT)
#use rs232(baud=57600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,restart_wdt)
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3,restart_wdt,force_hw)
*********BOOTLOADER.H
#define FIRMWARE_UPGRADE_VECTOR 0 // Bootloader at Start of memory
#define MAX_UPGRADE_AREA (0x500) // Space required by bootloader
#define MIN_FIRMWARE_UPGRADE_MEMORY_AREA (0x20) // Start of bootloder code
#define MAX_FIRMWARE_UPGRADE_MEMORY_AREA (MAX_UPGRADE_AREA-1) // End of bootloder code
#define APPLICATION_RESET_VECTOR 0x500 // New RESET Vector
#define APPLICATION_ISR_VECTOR 0x508 // New Interrupt Vector
#define LOADER_END MAX_UPGRADE_AREA -1
#define LOADER_ADDR MIN_FIRMWARE_UPGRADE_MEMORY_AREA
#build(reset=APPLICATION_RESET_VECTOR, interrupt=APPLICATION_ISR_VECTOR)
#define BUFFER_LEN_LOD 64
int buffidx;
char buffer[BUFFER_LEN_LOD];
#define ACKLOD 0x06
#define XON 0x11
#define XOFF 0x13
#SEPARATE
unsigned int atoi_b16(char *s);
#ORG LOADER_ADDR, LOADER_END auto=0 default
void real_load_program (void)
int1 do_ACKLOD, done=FALSE;
int8 checksum, line_type;
int16 l_addr,h_addr=0;
int32 addr;
// #if getenv("FLASH_ERASE_SIZE")>2
// int32 next_addr;
// #endif
int8 dataidx, i, count;
int8 data_boot[32];
while (!done || (counter_timer_boot <= TIMEOUT_BOOT)) // Loop until the entire program is downloaded
buffidx = 0; // Read into the buffer until 0x0D ('\r') is received or the buffer is full
do {
buffer[buffidx] = getc();
while ( (buffer[buffidx++] != 0x0D) && (buffidx <= BUFFER_LEN_LOD) );
putchar (XOFF); // Suspend sender
do_ACKLOD = TRUE;
counter_timer_boot = 0;
// Only process data blocks that start with ':'
if (buffer[0] == ':')
count = atoi_b16 (&buffer[1]); // Get the number of bytes from the buffer
// Get the lower 16 bits of address
l_addr = make16(atoi_b16(&buffer[3]),atoi_b16(&buffer[5]));
line_type = atoi_b16 (&buffer[7]);
addr = make32(h_addr,l_addr);
// If the line type is 1, then data is done being sent
if (line_type == 1)
done = TRUE;
else if ((addr < LOADER_ADDR || addr > LOADER_END) && addr < 0x2000)
#elif defined(__PCH__)
else if ((addr < LOADER_ADDR || addr > LOADER_END) && addr < 0x300000)
checksum = 0; // Sum the bytes to find the check sum value
for (i=1; i<(buffidx-3); i+=2)
checksum += atoi_b16 (&buffer[i]);
checksum = 0xFF - checksum + 1;
if (checksum != atoi_b16 (&buffer[buffidx-3]))
do_ACKLOD = FALSE;
if (line_type == 0) {
// Loops through all of the data and stores it in data
// The last 2 bytes are the check sum, hence buffidx-3
for (i = 9,dataidx=0; i < buffidx-3; i += 2)
data_boot[dataidx++]=atoi_b16(&buffer[i]);
// #if getenv("FLASH_ERASE_SIZE") > getenv("FLASH_WRITE_SIZE")
// if ((addr!=next_addr)&&(addr&(getenv("FLASH_ERASE_SIZE")/2-1)!=0))
// erase_program_eeprom(addr);
// next_addr = addr + 1;
// #endif
write_program_memory(addr, data_boot, count);
else if (line_type == 4)
h_addr = make16(atoi_b16(&buffer[9]), atoi_b16(&buffer[11]));
if (do_ACKLOD)
putchar (ACKLOD);
putchar(XON);
putchar (ACKLOD);
putchar(XON);
// #ifndef _bootloader
reset_cpu();
// #endif
unsigned int atoi_b16(char *s) { // Convert two hex characters to a int8
unsigned int result = 0;
int i;
for (i=0; i<2; i++,s++) {
if (*s >= 'A')
result = 16*result + (*s) - 'A' + 10;
result = 16*result + (*s) - '0';
return(result);
#ORG default
In the main code,
startup_system();
if(!input(PIN_E6))
real_load_program ();
}// if(!input(PIN_E6))
while (true)
restart_wdt();
etc...
This is the code, and the problem still remain on the 0x00000 address thet it's not a jump to the main but it's some part of a code involved in interrupt handling!
Thanks for the help |
Matro Guest
Posted: Mon May 05, 2008 4:25 am |
The code you just posted is neither small nor compilable.
It generates a huge amount of errors when I copy-paste it.
Post a small code that doesn't generate any compilation error except the one that corresponds to the problem you are encountering.
Matro |
Posted: Mon May 05, 2008 4:35 am |
The 'glaring' thing, is that it is the _main_ that needs the #build relocation, not the bootloader.....
Look again at the examples. ex_bootload.c, shows how the main code has to be relocated. It loads bootloader.h, which without the keyword '_bootloader' defined, relocates the code.
Posted: Mon May 05, 2008 5:59 am |
Ttelmah wrote: | The 'glaring' thing, is that it is the _main_ that needs the #build relocation, not the bootloader.....
Ok thanks.
I wiil try in that way and let you know.
I will study morre in deep the code example and then try to recompile.
I will let you know.
If doesn't work, I will then poste a code that make me go crazy.
![Smile](images/smiles/icon_smile.gif) |
Andrea Guest
Posted: Tue May 06, 2008 3:54 pm |
Anonymous wrote: | Ttelmah wrote: | The 'glaring' thing, is that it is the _main_ that needs the #build relocation, not the bootloader.....
Ok thanks.
I will try in that way and let you know.
I will study more in deep the code example and then try to recompile.
If doesn't work, I will then post a code that make me go crazy.
Thanks everybody.
Was my mistake in organize the bootloader and all the directives to reserve space.
Now it's clear what to do.
Just reserve space in my main program (using the bootload.c example to clarify) but previously I have to lad the bootloader alone.
Thanks again |
