preprocessor and compiler release
Fabri
PostPosted: Thu Nov 12, 2020 10:43 am     Reply with quote
Hi to all,
I have compilers version 4 and 5 used for different project. I need to check compiler version when I build project. Is there any preprocessor function can give me error in case I use different compiler than I defined ?
Thanks for your support,
PostPosted: Thu Nov 12, 2020 10:51 am     Reply with quote
You can do a preprocessor test like this (from the manual...):
#IF getenv("VERSION")<3.050
     #ERROR Compiler version too old
#ENDIF
Obviously for a specific version, you can test with == instead of <
Fabri
PostPosted: Thu Nov 12, 2020 11:02 am     Reply with quote
Thanks Ttelmah for prompt reply and suggestion.
I check user guide now for more information.
Regards,
