how to define pins as array?
40inD
PostPosted: Thu Apr 24, 2008 1:44 am     Reply with quote
How to define pins as array? I want to declare pins like
A[0]=pin_A0;
A[15]=pin_B7;
and work with pins in array style i.e. On or Off the pin by this command:
A[i]=ON
PostPosted: Thu Apr 24, 2008 2:04 am     Reply with quote
You could declare an array of bits, and then set the base address of the
array to the address of PortA with the #locate directive. Note that you
must also set the TRIS for the Ports, to make all pins be outputs.
Also, on the 16F877, PortA outputs A6 and A7 don't exist. On other
PICs, one pin on PortA might be an input-only pin.
#include <16F877.H>
int1 array_of_bits[16];
#locate array_of_bits = 0x05  // Address of PortA on 16F877
int8 i;
set_tris_a(0x00);
set_tris_b(0x00);
array_of_bits[0] = 1;
array_of_bits[1] = 0;
array_of_bits[2] = 1;
array_of_bits[3] = 0;
array_of_bits[4] = 1;
array_of_bits[5] = 0;
array_of_bits[6] = 1;
array_of_bits[7] = 0;
array_of_bits[8] = 1;
array_of_bits[9] = 0;
array_of_bits[10] = 1;
array_of_bits[11] = 0;
array_of_bits[12] = 1;
array_of_bits[13] = 0;
array_of_bits[14] = 1;
array_of_bits[15] = 0;
40inD
PostPosted: Thu Apr 24, 2008 3:28 am     Reply with quote
Hmmm. I tried to make this:
#include <16F877A.h>
#device adc=8
#FUSES XT                       //Crystal osc <= 4mhz
#FUSES WRT_50%                  //Lower half of Program Memory is Write Protected
byte R[24]; // relays array
{int i;
R[0]=pin_A4;
R[1]=pin_A5;
R[2]=pin_E0;
R[3]=pin_E1;
R[4]=pin_E2;
R[5]=pin_C0;
R[6]=pin_C1;
R[7]=pin_C2;
R[8]=pin_C3;
R[9]=pin_D0;
R[10]=pin_D1;
R[11]=pin_D2;
R[12]=pin_D3;
R[13]=pin_C4;
R[14]=pin_C5;
R[15]=pin_C6;
R[16]=pin_C7;
R[17]=pin_D4;
R[18]=pin_D5;
R[19]=pin_D6;
R[20]=pin_D7;
R[21]=pin_B1;
R[22]=pin_B2;
R[23]=pin_B4;
  setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
 for (i=0; i<=23; i++)
   output_high(R[i]);
 delay_ms(250);
And in Proteus it works fine.
Matro
PostPosted: Thu Apr 24, 2008 3:41 am     Reply with quote
Yes, it will work.
It's simpler to implement than PCM programmer's method, but definitely less efficient.
Matro
PostPosted: Thu Apr 24, 2008 11:47 am     Reply with quote
This thread has an code for another method.
http://www.ccsinfo.com/forum/viewtopic.php?t=18949
