PIC program code gets corrupted/changed
Christophe
PostPosted: Tue Apr 22, 2008 9:31 am     Reply with quote
Hi readers,
I'm having this major problem; the PIC program's code gets corrupted/changed in some way. The board starts up normally but then USART routine to isn't working anymore.
I've also had some boards (PIC's) that even didn't start anymore.
I know it is a software problem because I can reprogram the bootloader in the PIC's flash and then reprogram it, and after that my program works again. It does not happen a lot. It's happened in I guess 10 out of 100 boards.
Some specs:
- I use a bootloader which is at upper memory.
- I have a PIC16LF877A
I don't know how I can debug this, your advice please.
- What can be theoretically the cause of the code getting changed?
- What can I do to prevent this?
Matro
PostPosted: Tue Apr 22, 2008 9:40 am     Reply with quote
I have such a problem because I programmed my PIC powered by the board power supply that was an isolated one.
So there was GND problems.
Matro.
Christophe
PostPosted: Wed Apr 23, 2008 12:49 am     Reply with quote
I don't think it's a programming problem as my boards initially get programmed OK. They worked OK.
PostPosted: Wed Apr 23, 2008 1:07 am     Reply with quote
works again.
I don't see how that makes it a software problem. It could be software
or hardware. In other words, the flash is getting erased or glitched.
The cause of that could be in hardware or software.
Do the same boards always fail ?
If so, get rid of the bootloader on those boards. Also get rid of any
other code that writes to flash program memory. If these boards now
start working, then maybe you have a problem with the bootloader
routine being accidently called when power is turned on to the PIC.
Use your programmer to read the flash memory of the PICs that
have failed. Compare it to a good image. What data is written to
the damaged area in the program memory ? Is it 0x3FFF ? Or
something else ? Can you tell if the bootloader is doing the writing ?
Hardware questions:
1. What is the Vdd voltage for the PIC ?
2. What is the crystal frequency ? Are you using a crystal ?
If so, what is the value of the load capacitors ?
3. Do you have a 100 nF ceramic capacitor between each Vdd pin
and ground ? Are they placed very close to the PIC ?
4. Are you using a voltage regulator for the Vdd voltage ?
If so, do you have a 10 uF tantalum capacitor on the output ?
5. What is the value of the pull-up resistor on the MCLR pin ?
6. What is the ambient temperature when the PICs fail ? Are they
kept at room temperature all the time ?
Matro
PostPosted: Wed Apr 23, 2008 1:43 am     Reply with quote
I'm gonna add this question :
How is powered your PIC during programmation (type of supply, wiring, ...)?
Matro.
Christophe
PostPosted: Wed Apr 23, 2008 2:06 am     Reply with quote
Hi, thanks for getting deeper into this.
works again.
- What possible hardware causes are there?
No, I can't say when it happens. When I reprogram them, they are fine and the program works again.
I'm also thinking that it might be possible that the bootloader routine is getting called accidentally; it's activated by receiving 2 X the same character. These characters have to be sent by another processor.
The bootloader code is:
// Include gogoloader.h in main program
// #ORG LOADER_BEGIN, LOADER_END {} in main program
#include <16F877A.H>
#device *=16
//#case
#fuses XT, PUT, NOWDT, NOPROTECT, NOLVP, NOCPD, NOWRT, NOBROWNOUT
#define READY_FOR_NEXT  0x11                                   // define possible reply bytes
#define FINISH_FLAG     0x55
#define BOOTLOADER_OVERWRITE  0x80
#define SerBufferSize 45                                       // serial input buffer size
#include "GOGOLOADER.H"
#ORG LOADER_BEGIN, LOADER_END auto=0 default                   // #org tells the compiler where to put the procedures in memory
#use DELAY (clock=4000000)
#use rs232 (baud = 19200, parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
unsigned int a2i (unsigned char asciiByte)                     // a slim version of atoi().converts ascii text to integer
{                                                              // i.e. '1' = 1, 'A' = 10
      if (asciiByte >= 'A' && asciiByte <= 'F')
         return((asciiByte) - 'A' + 10);
      else if (asciiByte >= '0' && asciiByte <= '9')
         return ( asciiByte - '0');
unsigned int read8 ()
{                                                              // convert two ascii text to a 8 bit integer
     return( (a2i(getc()) << 4) + (a2i(getc())) );
void main ()
   unsigned int16 Buffer[SerBufferSize];                       // serial input buffer
   int1 notDone = 1, CODE_TOO_LARGE = FALSE;
   unsigned int recLen;                                        // HEX file record length
   unsigned int16 writeAddr, timeout = 0;                          // HEX file write address
   unsigned char recType;                                      // HEX file record type
   unsigned char i=0,j, triggers_found = 0;                    // general counters
   unsigned int16 UserBootVectorAddr;                          // holds the address of our new boot vector
   unsigned int16 User_BootVector [4] = { 0,0,0,0 };
   for ( i = 2; i > 0 ; i-- )
      while ( !kbhit () && (++timeout < 0xFFFF) )               // 2 Seconden tijd om downloadcommando te sturen: 0xAA , 0xAA
         delay_us (16);
      if ( kbhit () )
         if ( getc () == 170 )
            triggers_found++;
   if ( triggers_found == 2 )
      putc ('L');
      UserBootVectorAddr=label_address(UserBootVector);           // Get the adress in the bootloader where the reset vector will be
      while (notDone)
         while (getc() != ':') ;                                  // Wait for ':'
         recLen = read8();                                        // Hex file Record length
         recLen >>= 1;                                            // we divided the Length by 2.
        // Each memory location on the PIC (16 bit) is
        // twice the unit size of the HEX file (8 bit).
         writeAddr  = ((int16)read8() << 8) + read8();            // Write Address
         writeAddr >>= 1;                                         // divide by 2
        // The physical address on the PIC is half the address in the HEX file.
         getc ();                                                 // ignore the first digit, it is always '0'
         recType = getc();                                        // Get the Rec Type
         if (recType == '1')                                      // End of file record
            notDone = 0;
         else if (recType == '0')                                 // data record: get the data
            for (i=0; i < recLen ; i++)
                Buffer[i] = read8() + ((int16)read8() << 8);
            if ((writeAddr >= 0x2100) && (writeAddr <= 0x21FF))      // if data is in the EEPROM area
               write_eeprom((int) writeAddr, (int) Buffer[i]);
            else if ((writeAddr >= 0x2000) && (writeAddr <= 0x20FF)) // else if data is in the Configuration register area
            {}                                                        // Can't write configuration registers -> just skip.
            else if ( (writeAddr >= LOADER_BEGIN) && (writeAddr <= LOADER_END))   // else if data overlaps the bootloader code -> halt
               CODE_TOO_LARGE = TRUE;
            {                                                      // else -> data is in program area
               for (i=0; i < recLen ;i++)
                  if (!CODE_TOO_LARGE)
                     if ((writeAddr < 0x004) && (i<4) )
                   User_BootVector[i] = Buffer[i];
                        write_program_eeprom (writeAddr + i, Buffer[i]);
            putc (READY_FOR_NEXT);                                // Tells the PC to send the next line
      if ( CODE_TOO_LARGE )
         putc ( BOOTLOADER_OVERWRITE );
         for ( i=0; i < 4 ;i++)
              write_program_eeprom (UserBootVectorAddr + i, User_BootVector[i] );
         putc ( FINISH_FLAG );                                    // Tells the PC that we are finished
      for (j=0;j<255;j++)                    // this loop gives the chip time to finish sending the serial byte before resetting it self.
         for (i=0;i<255;i++) {};
      //delay_ms ( 2 );
   } // While notdone
UserBootVector:
#asm                          // This is a reboot command written in Assembly.
      MOVLW   0x00                  // these four commands will be overwritten with the boot vector we obtain from the HEX file.
      MOVWF   0x0A
      GOTO   0x00
      NOP
      NOP
#endasm
}// main
#ORG default
I did that. There are not many differences.
file 1 (OK): http://users.[spam].be/chs/Werk/BOOTLOADER_PIC_2_4_IMAGE.HEX
file 2 (corrupted): http://users.[spam].be/chs/Werk/BOOTLOADER_PIC_2_4_IMAGE_ACQUET.HEX
How can you tell the bootloader is doing the writing?
Hardware questions:
That is 3V, I have a PIC16LF877A.
I have a ceramic resonator, it has capacitors built in.
Yes, 1 at each Vdd pin + 1uF + 47uF electrolytic cap, for voltage stability.
Yes a TI TPS78930; it has 4u7 at the output.
http://users.[spam].be/chs/Werk/mclr_circuitry.jpg
But recently I've changed it to a 33Kohm pullup close to the PIC and a 2k2 series resistor + 1nF/50V filter cap on MCLR. However the failing boards have the circuitry as shown in the link.
That is room temperature.
Christophe
PostPosted: Thu Apr 24, 2008 6:42 am     Reply with quote
Any advices?
- Is it possible the code gets corrupted changed, when there is a low battery situation, like a grey zone for the PIC supply voltage..
PostPosted: Thu Apr 24, 2008 11:23 am     Reply with quote
I still have to look at it some more. But I have a basic philosophy
on fixing unknown problems. Everything that you are doing that is
different from the "baseline", should changed so it is same as the
baseline. Examples:
1. You're using a bootloader. Don't use it. Remove the code for it.
I assume you're using surface mount PICs. Can the PICs be
re-programmed with an ICD2 by the ICSP method ? Are the boards
setup for that ? If so, design a version of your code that does not use
the bootloader. Run several boards with it and see if the failure stops.
If so, you have found the basic problem and you can work on it.
2. You're running a resonator. Use a crystal (and capacitors) instead.
3. You're running at 3v. Try running it at 5v instead.
4. You're using a 16F877A. Use the "non-A" version instead.
The "A" version was always more sensitive to power supply noise than
the original non-A version.
5. You're using the "LF" version. When you run it at 5v, you could also
switch to the "non-LF" version.
6. Board layout can be important. If you're using a 2-layer board
without a gridded power and ground layout, then change it to a 4-layer
board, or grid the power and ground. Don't put the PIC's power and
ground pins at the end of a stub trace. Those pins must be right on top
of a main power or ground trace. A "stub" is like a cul-de-sac street.
Avoid stubs. They create a lot of noise on the power and ground pins.
7. You're using a unusual MCLR circuit. Change to a standard circuit.
The 390K is a mistake. That's too high of an impedance. I would
reduce it to 10K. Get rid of all the other components in the MCLR circuit
and just use the 10K pullup. Do this on all the failing boards and see
if it fixes the problem.
You don't have to do all of these things at once. Maybe just do the last
one, with the MCLR circuit, because I think it might be the best bet.
Christophe
PostPosted: Fri Apr 25, 2008 4:03 am     Reply with quote
Hi, thanks for replying.
I still have to look at it some more. But I have a basic philosophy on fixing unknown problems. Everything that you are doing that is different from the "baseline", should changed so it is same as the baseline. Examples:
I know, some things are different. The problem is I can't change that much. The board is allready in production.
I could do that, but the bootloader gives me the advantage to program the PIC processor with having to open the device and plugin the programmer which is very extensive.
It's a good idea to find out whether the bootloader is the cause.
I saw you write this alot; why is a X-tal better?
That's impossible with the current design. 3V3 however would be possible. Would that be better?
I'm planning to change the MCU after reading this: http://www.ccsinfo.com/newsdesk_info.php?newsPath=ALL&newsdesk_id=91
See this topic for more info about board layout. I have 3 boards stacked. http://www.ccsinfo.com/forum/viewtopic.php?t=33300&highlight=
As you can read, I also have random reset problems.
However the failing boards have the circuitry as shown in the link. The 390K is a mistake. That's too high of an impedance. I would
I've changed this in the newest revision of the boards:
