		| Author | Message |
		| Lost_whit_servo Guest
				| servo pwm problem, what´s wrong, where´s the errors? |
				|  Posted: Sun Apr 20, 2008 12:22 pm |   |
				| I want to drive one or more rc servo but...I can´t find where´s the error(s). Can some one help me?
 thanks in advance
  	  | Code: |  	  | #include <16F628.h>
 #use delay(clock=20000000) // Fosc
 #fuses HS,NOWDT,NOPUT
 #use fast_io(B)
 #bit RB1 = 0x06.1
 #bit RB2 =0x06.2
 static int16 k=0;
 #INT_TIMER0
 void tmr0_int()
 RB2 = !RB2;      //int is working?
 k++;
 set_timer0(206);  // 10useg
 int i;
 set_tris_b(0);
 output_low(PIN_B1);
 setup_timer_0(RTCC_INTERNAL | RTCC_DIV_1);
 enable_interrupts(INT_RTCC);
 set_timer0(206);   // 10useg int
 for(i=90;i<=150;i=i+30) //900useg, 1200useg, 1500useg
 if(k<=i)
 bit_set(*RB1,1);
 while(k<=2000) //itxaron 200mseg bete arte
 bit_clear(*RB1,0);
 k=0;
		| ckielstra
				|  Posted: Sun Apr 20, 2008 1:41 pm |   |
				| I'm not really sure what you want your code to do but there are several errors: 1) This loop will never exit. Even with the timer interrupt increasing the value of K it's value will soon be reset to 0 and never reach 2000. 	  | Code: |  	  | while(k<=2000) //itxaron 200mseg bete arte {
 bit_clear(*RB1,0);
 k=0;
 2) This code for changing the value of an I/O-port is completely wrong: *RB1 means 'take the contents of the variable pointed to by RB1', with RB1 being a 1-bit variable this will be either the contents of address 0 or 1. Completely not what you intend to do.
 Possible methods to clear an I/O-port are:
 I like method_3 because you don't have to manually specify the port's memory address which makes it very easy to change the program to another processor. 	  | Code: |  	  | Method 1: #byte PORT_B = 0x06
 #bit RB1 = PORT_B.1
 RB1 = 0;
 Method 2:
 bit_clear(PORT_B, 1);
 Methode 3:
 output_low(PIN_B1);
 An interrupt routine that has to execute every 10us is extremely fast and will consume all your processor's execution time. 	  | Code: |  	  | void tmr0_int() {
 k++;
 To understand this you have to know that an interrupt has a lot of overhead for saving all registers on entering the interrupt and restoring the registers on exit. Depending on the number of registers this takes about 45 instructions on a PIC16 and 80 on a PIC18.
 Your timer interrupt routine takes about 10 instructions, a total of: 45 + 10 = 55 instructions.
 The processor is running at 20MHz, or 5 instructions per us.  Meaning it takes 11us to execute 1 interrupt and leaving no time to execute your main program.
 Servo programs have been discussed many times before on this forum, I suggest you use the search function to find those discussions. Here is one link: http://www.ccsinfo.com/forum/viewtopic.php?t=30139
 | You cannot post new topics in this forum You cannot reply to topics in this forum
