Warning 216 _____ Interrupt disabled during call to prevent.
foodwatch
PostPosted: Sun Apr 20, 2008 12:01 pm     Reply with quote
I am using an 18F4550 using int_rda for capturing rs232 data and using int_timer1 for maintaining a seconds counter. I disable the appropriate interrupt while the other is working to prevent re-entering the irq routines but when I compile I get the following message in my watch output... (I have used x's for file name)
Warning 216 xxxxxx.c Line 982(0,1) Interrupt disabled during call to prevent re-entrancy: (@ADDFF).
The only problem is that my source code ends at line 979. It appears that this is causing the interrupt to become disabled, but I cannot see anything that would cause it... Anyone have any ideas?
PostPosted: Sun Apr 20, 2008 2:41 pm     Reply with quote
It'll happen whenever you use the same functions inside an interrupt, and in the main code. It is only a warning. A quick search here, will find a huge amount about it. Since it applies to the 'main' as a whole, the line number is always the last line of this.
foodwatch
PostPosted: Sun Apr 20, 2008 5:58 pm     Reply with quote
Thanks.... its been a long weekend and getting a bit foggy....
