OJ Guest
Help AD7705 @ 1MHz with 1.225 REF |
Posted: Mon Apr 21, 2008 2:05 pm |
Can someone please help I modified the AD7705 driver with the following:
I am using a PIC18F87J60 @ 25MHz. A MIC1555 is the master clock set @ a frequency of 1MHz and a voltage reference at 1.225V.
I turned off the MCLK out by writing 0x10 as the rate, have reset tied high and DRDY is not connected.
Whats happening is I read the same value no matter what is on the input.
I checked the master clock and it is generating 1MHz. I have 5 boards and I get the same result.
Thanks in advance.
the ADC should be setup unipolar,gain=1,cal=normal rate=20hz
#define ADC_DO PIN_D0
#define ADC_DI PIN_D1
#define ADC_CLK PIN_D2
#define ADC_CS PIN_H2
#define OSC_CS PIN_H0 //MIC1555 enable
//Calibration
//#define ADC_NORMAL 0
//#define ADC_SELF 64
//#define ADC_ZERO_SCALE 128
//#define ADC_FULL_SCALE 192
//Gain
//#define ADC_GAIN_1 0
//#define ADC_GAIN_2 8
//#define ADC_GAIN_4 16
//#define ADC_GAIN_8 24
//#define ADC_GAIN_16 32
//#define ADC_GAIN_32 40
//#define ADC_GAIN_64 48
//#define ADC_GAIN_128 56
//Polarity
//#define ADC_BIPOLAR 0
//#define ADC_UNIPOLAR 4
//Rates
//#define ADC_20 16
//#define ADC_25 17
//#define ADC_100 18
//#define ADC_200 19
/********************Convert ADC Value To Volts ********************************/
float ToVolts(long data)
return ((float)data*1.225/0xffff);
/******************** Write To ADC *********************************************/
void write_adc_byte(int data)
int i;
output_low(ADC_CS);
for(i=0;i<8;i++)
output_low(ADC_CLK);
output_bit(ADC_DI, shift_left(&data,1,0));
output_high(ADC_CLK);
output_high(ADC_CS);
/******************** Disable ADC **********************************************/
void adc_disable(void)
write_adc_byte(0x04);//Place in standby mode
output_low(OSC_CS);//Turn Off Oscillator
/******************** Enable ADC **********************************************/
void adc_enable(void)
output_high(OSC_CS);//Turn On Oscillator
write_adc_byte(0x00);
/******************** Read Value From ADC **************************************/
long read_adc_word(void)
int i;
long data;
output_low(ADC_CS);
for(i=0;i<16;i++)
shift_left(&data,2,input(ADC_DO));
return data;
/******************** Setup ADC **************************************/
void setup(void)
write_adc_byte(0x20);
write_adc_byte(0x10);
/******************** Initialize ADC *******************************************/
void init_ADC(void)
setup();
delay_ms(3000);
/******************** Read ADC Value From Specified Channel ********************/
long read_adc_value(int1 ch)
long value;
if(ch){write_adc_byte(0x39);}
else{write_adc_byte(0x38);}
//value=/*ToVolts(*/read_adc_word();//);;
return value;
here is the main routine
init_ADC();
printf("RAW=%Lu\r",read_adc_value(0));
Posted: Mon Apr 21, 2008 3:28 pm |
What you have posted, has the entire actual 'reading' code remarked out. 'value', will just contain a random value, dependant on what happened to be in the chip's memory when it turned on....
