drot_bigear
PIC16F887 - Dual PWM out. CCP1 not working |
Posted: Fri Apr 18, 2008 1:27 pm |
Hi all.
I hope someone can help me on this one.
I'm doing a minor project with a PIC16F887 - 40pin DIP
Need 2 PWM out with same frequency but different duty cycles.
I've set both ccp modules up the same way, but I can't measure anything on the CCP1 output, pin17.
CCP2 works flawless.
I've read through most of this forum searching for CCP1 subjects.
Tried some of the codes that were suggested for others, including this code
Code: | int16 pwm_l, pwm_r;
setup_ccp1(CCP_PWM);
setup_ccp2(CCP_PWM);
setup_timer_2(T2_DIV_BY_1, 128, 1);
pwm_l = 128;
pwm_r = 128;
set_pwm1_duty(pwm_l);
set_pwm2_duty(pwm_r);
while(1); // Prevent PIC from going to sleep.
It didn't work.
This is how my own code looks at the moment.
unsigned int Duty = 0;
void Update_PWM()
set_pwm1_duty(Duty);
set_pwm2_duty(Duty);
Duty +=4;
if (Duty > 200) Duty = 0;
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_1,200,1); //8MHz/4/200 = 10kHz
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
set_pwm2_duty(0); //to avoid high start output
setup_oscillator(OSC_8MHZ);
do {
Update_PWM();
} while (TRUE);
surely hope someone can help me.
Best regards
Jacob |
Posted: Fri Apr 18, 2008 2:00 pm |
I don't have a 16F887, but I do have 16F886 and it's a very similar PIC
except it's in a 28-pin package. I tested the program shown below
with compiler vs. 4.071 and it worked. I got a PWM signal on pins 12
and 13 (CCP2 and CCP1) with a frequency of 7.75 KHz, and a 25% duty
cycle.
Code: | #include <16F886.H>
#use delay(clock = 4000000)
int16 pwm_l, pwm_r;
pwm_l = 128;
pwm_r = 128;
If it doesn't work for you, then:
1. Check the external circuit on the CCP pin. Is it loading down the
signal too much, so that you can't see the signal ?
2. Post your compiler version.
3. Post a complete test program (but short) as I have shown above,
showing the #fuses and #use delay() statements. |
drot_bigear
Posted: Fri Apr 18, 2008 5:08 pm |
Compiler version 4.016
I have no external circuit on the CCP1 pin yet.
CCP2 has a 1k res and a LED to gnd.
my fuses from my .h file:
#include <16F887.h>
#device adc=10
#FUSES NOBROWNOUT //No Reset when brownout detected
#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#use delay(clock=8000000)
Posted: Fri Apr 18, 2008 5:42 pm |
Quote: | Compiler version 4.016 |
That's an early version, and the setup_ccpx() routines are buggy in that
version. You can make it work if you substitute the "my_setup_ccpx()"
routines that are shown in the program below. Use them instead of
the normal routines. In these two new routines, I have just copied what
CCS does in vs. 4.071.
#byte CCP1CON = 0x17
#byte CCP2CON = 0x1D
#byte PWM1CON = 0x9B
void my_setup_ccp1(int8 value)
output_low(PIN_C2);
CCP1CON = value;
PWM1CON = 0;
void my_setup_ccp2(int8 value)
output_low(PIN_C1);
CCP2CON = value;
int16 pwm_l, pwm_r;
my_setup_ccp1(CCP_PWM);
my_setup_ccp2(CCP_PWM);
pwm_l = 128;
pwm_r = 128;
drot_bigear
Posted: Sat Apr 19, 2008 4:44 am |
Well that works much better.
Thank you very much for a quick reply.
I'll make sure to save that info for further usage
Best regards
Jacob |
