converting from 12f683 to 16f84 or similar.
rb8720
PostPosted: Mon Apr 21, 2008 2:16 pm     Reply with quote
I wrote some code a while back for a 12f683 with alot of help from others. I am astill a total newb. I got it working like i want but now I find myself in need of more inputs and outputs and was considering converting to a 16f84 or similar. How hard would it be to convert my existing code to work on 16f84? If needed I can post the code i have here.
Thanks,
RB8720
PostPosted: Mon Apr 21, 2008 2:26 pm     Reply with quote
How hard would it be to convert my existing code to work on 16f84 ?
That's an older PIC. It doesn't have an internal oscillator, or an A/D
or a comparator or anything, really. A better chip would be the 16F88.
Or possibly the 16F628 or 16F628A (no A/D in those two PICs).
How hard would it be to convert my existing code ?
If you use the CCS functions entirely, then it should be fairly easy to
port the code from one PIC to another. Change the #include statement
to use the .H file for the new PIC. If you're using peripheral modules,
make sure you specify the correct pins, if required, by #use statements.
rb8720
PostPosted: Mon Apr 21, 2008 4:57 pm     Reply with quote
thanks, i think i'll go with the 16f88. here is my code. could you tell me what i would need to change?
//PREPROCESSOR section/////////////////////////////////////////////////////////////////////////////////////////////
#include "12F683.H"      //PIC chip file (don't also specify in cmd prompt)
#include "delay_ms.h"      //Delay function used below
            //#include files must be in same folder as cc5x.exe if no path
#define pin7 1<<0               //Pin 7, bit 0
#define pin6 1<<1               //Pin 6, bit 1
#pragma config = 0b.0.1100.0100   //Brown-out Detect disabled (0)
            //Code Protect off (1)
            //MCLR set to 'Internal' (1) (LEDs don't flash with other setting)
            //Powerup timer enabled (0)
            //Watchdog timer disabled (0)
            //Oscillator set to INTRCIO (100)
void init_ports(void) {
   TRISIO = 0b11111111; // SET AS INPUT
   CMCON0 = 0x07;       // Set GP<2:0> to digital I/O
   ANSEL = 0;
   WPU = 0b00000011;
int get_key (int button) {
   // Is GP5 low - no so exit
   if (GPIO & button) return 0; // no key yet
   delay_ms(1); // wait for key to settle
   // Is GP5 high ? yes so exit = false key.
   if ((GPIO & button) > 0) return 0; // was a false key so restart
   return 1; // key ok so return valid
// Start here
void main () {
   unsigned int i, c;
   char next;
   uns16 ms;
   char button_func;
   init_ports();
   //GPIO = 0xFF;
   button_func = 0; // 0 = double shot, 1 = rapid fire - double shot is default
   while (1) {
      // Key hit yet ?
      while ((GPIO & pin6) && (GPIO & pin7)) { ; } // wait for input going low.
      // Is the key hit (and is it valid) ?
      if (get_key (pin7)) { // Double shot or rapid fire
         while (!(GPIO & (pin7))) { // loop until input goes high.
            if (button_func == 0) { // double shot
                  TRISIO.2 = 0;//SET TO OUTPUT
                  GPIO.2 = 0; // Pin 5 output ( trigger on)
                  delay_ms(67);
                  TRISIO.2 = 1;//SET trigger TO input
                  GPIO.2 = 1;  // trigger off
               TRISIO.2 = 0;//SET trigger TO OUTPUT
               TRISIO.4 = 0; // SET X BUTTON TO OUTPUT
               GPIO.2 = 0; // 2nd pin5 output (trigger on)
               delay_ms(43);
               GPIO = 0b11101011; // pin 5 and pin 3 on (X Button)
               delay_ms(154);
               TRISIO.2 = 1;//SET trigger TO INTPUT
               TRISIO.4 = 1; // SET X BUTTON TO INPUT
               GPIO = 0b11111111; // pin 5 and 3 off
                  TRISIO.5 = 0; // SET Y TO OUTPUT
                  GPIO.5 = 0 ;//  Y BUTTON PIN2 ON
                   delay_ms(370);
                  TRISIO.5 = 1;// Y BACK TO INPUT
                  GPIO.5 = 1; // Y  off
                  delay_ms(450);
               GPIO.5 = 0; // pin2 on
               delay_ms(37);
               GPIO.5 = 1; // Y OFF
               delay_ms(190);
            } else { // rapid fire
               TRISIO.2 = 0; //TRIGGER TO OUTPUT
               GPIO.2 = 0;// TRIGGER ON
               delay_ms (250);
               TRISIO.2 = 1;// TRIGGER BACK TO INPUT
               GPIO.2 = 1;// TRIGGER OFF
               delay_ms (250)
      } else if (get_key (pin6)) { // Rapid reload
         OPTION = 0b.0010; //0 Assigns the prescaler to TMR0, 8 clock pulses per PIC
         ms = 0;
         TMR0 = 2;
         do {
             next += 125;
             while (TMR0 != next);   // wait 1ms
             ms++;                 // increment timing counter
         } while (!(GPIO & pin6)); // loop until input goes high.
         if (ms < 2200) {          // button held less than 3000ms - rapid reload
             TRISIO.4 = 0; // X SET TO OUTPUT
             GPIO.4 = 0; // X ON
             delay_ms (40);
             TRISIO.4 = 1; //X TO INPUT
             GPIO.4 = 1;// X OFF
             delay_ms (1050);
             TRISIO.5 = 0; // Y TO OUTPUT
             GPIO.5 = 0; // Y ON
             delay_ms (400);
             TRISIO.5 = 1; // Y BACK TO INPUT
             delay_ms (600);
             GPIO.5 = 0; // Y ON
             delay_ms (400);
          } else {
                button_func = 1;
             } else {
                button_func = 0;
   } // infinite while
thanks rb
PostPosted: Mon Apr 21, 2008 5:32 pm     Reply with quote
Your question is really that you want someone to convert your program
from the CC5X compiler to CCS.
PostPosted: Mon Apr 21, 2008 6:09 pm     Reply with quote
crap, i was thinking there were pretty much the same. Sorry. Im still very
new to this. So i guess the answer is yes to convert to ccs and convert to
16f88. any help would be greatly appreciated.
Thanks,
RB8720
