confuse about strlen
chongado
PostPosted: Sun Apr 26, 2009 9:39 pm     Reply with quote
Hi there, I'm confusing about function strlen()
when I coding like this
char str[10];
str[0]='a';
when I show the result of strlen(str), It'll be 3.
why??? why it didn't be 1?
Question
asmallri
PostPosted: Sun Apr 26, 2009 9:53 pm     Reply with quote
You did not use any string functions to populate your string. If you want to do it manually then you need to terminate the string with a 0x00.
char str[10];
str[0]='a';
str[1]=0x00;
This will give you a string length of 1.
Regards, Andrew
chongado
about terminate character
PostPosted: Sun Apr 26, 2009 10:25 pm     Reply with quote
Thank you.
Wayne_
PostPosted: Mon Apr 27, 2009 2:07 am     Reply with quote
char str[10]; defines a char array which can hold upto 10 characters.
A string is series of chars terminated with a 0 NOT the char '0' but the value 0 which is the same as the char '\0' or null
Your code defines a char array and then sets the first value to 'a' the rest is random data and it just so happens that when you ran your code str[3] == '\0' which meant that strlen(str) returns the value 3.
As you have defined your char array as [10] you can only store a tring of upto 9 values for your string as the last char must contain the terminator '\0' or 0
chongado
PostPosted: Mon Apr 27, 2009 3:08 am     Reply with quote
Thank you
You mean I should use the last of array to '/0'
can I code this " str[1]='/0' ", right?
Wayne_
PostPosted: Mon Apr 27, 2009 4:48 am     Reply with quote
Make sure you use the correct \
If you only want the one char in your string then you need to do
str[0] = 'a';
str[1] = '\0';
or you could do
strcpy(str, "a");
which may be better because if you change the number of chars the first
way becomes complicated and is prone to errors.
str[0] = 'h';
str[1] = 'e';
str[2] = 'l';
str[3] = 'l';
str[4] = 'o';
str[5] = '\0';
same as
strcpy(str, "hello");
chongado
Thank you
PostPosted: Mon Apr 27, 2009 11:54 pm     Reply with quote
Hi There thank you so much I can do it ^^
'\0' lovely character
