Need to get exactly 10ms int with internal TIMER1 18f4523
E_KARVELAs
PostPosted: Sat Apr 12, 2008 6:13 pm     Reply with quote
Hi
I need to get exactly 10ms int with internal TIMER1 on PIC18F4523 but some how i lose 1 sec every minute.Confused
#include <18F4523.h>
#device ICD=TRUE
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES BORV21                   //Brownout reset at 2.1V
#FUSES PUT                      //Power Up Timer
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOLPT1OSC                //Timer1 configured for higher power operation
#FUSES MCLR                     //Master Clear pin enabled
#include <flexy_lcd.c>
 int dec_sec=0
 int sec_time_count=0;
    setup_oscillator(OSC_4MHZ|OSC_INTRC|OSC_IDLE_MODE|OSC_PLL_ON);
     set_timer1(55536);                        //10000 x 1ms=10ms overflow
     setup_timer_1(T1_INTERNAL|T1_DIV_BY_1); //internal 31khz crystal
for(;;){
      lcd_gotoxy(1,1);
        printf(lcd_putc,"set_time %5d.%02u       \n                       ",sec_time_count,dec_sec)   ;
      } // for(;;) void
    } // void main
#INT_TIMER1
void micro()
  set_timer1(get_timer1()+55536);
  if(++dec_sec>99){  // 100x10ms=1sec
     dec_sec=0;
  ++sec_time_count;
I have compare the Timer1 int with My casio watch it seems to be 1 sec back for every min. Sad is there any way i can fix the issue?
---- GREECE ----
PostPosted: Sat Apr 12, 2008 7:02 pm     Reply with quote
Check table 26-8 in the datasheet. Typical accuracy of the internal RC oscillator is 1%, but can be as bad as 2%.
2% of 1minute = 1.2 seconds.
If you want to improve on this you will have to use an external (crystal based) oscillator.
E_KARVELAs
PostPosted: Sat Apr 12, 2008 7:10 pm     Reply with quote
Wink NIce.U got right...than i should change as soon as posible to external
32.768KHz crystal.
---- GREECE ----
E_KARVELAs
Can't have 1 sec external TIMER1 int with 18f2550
PostPosted: Tue Apr 15, 2008 12:07 pm     Reply with quote
Hi
I have changed the hardware im using external (32.768KHz crystal with 33pF )to produce
1 sec interrupt but im going forward 1 sec every min. Confused very strange Sad i done everything but i don't understand.im using internal 8Mhz
primary clock with PLL for cpu clock .
Ive done everything ...
Any suggestion ??Sad
#include <18F2550.h>
#device ICD=TRUE
#device adc=8
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES NOIESO                     //Internal External Switch Over mode enabled
#FUSES NOPBADEN                 //PORTB pins are configured as digital I/O on RESET
#FUSES PLL12                    //Divide By 12(48MHz oscillator input)
#FUSES CPUDIV1
#FUSES NOUSBDIV                 //USB clock source comes from primary oscillator
#FUSES NOVREGEN                 //USB voltage regulator disabled
#use delay(clock=8000000)
int sec=0, min=0,hour=0;
void main(){
   setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1|T1_CLK_OUT);
   setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_PLL_ON);
 for(;;){
 lcd_gotoxy(1,1);
 printf(lcd_putc"%02u:%02u:%02u"hour,min,sec);
#int_TIMER1
void  TIMER1_isr(void)
  set_timer1(32768);     //2^16=  65536/2 = 32768 * 1/32.768Hz <--- (1sec)
         if (++sec>59){
                       sec=0;
         if(++min>59){
                       min=0;
                       hour++;
  Timer1 is 16bit so
   2^16=  (65536/2)*1/32768=1.000000sec  exacly
---- GREECE ----
E_KARVELAs
PostPosted: Tue Apr 15, 2008 1:35 pm     Reply with quote
Hi again
Searching the forum along time for this issue i found some good info on this issue:
http://www.ccsinfo.com/forum/viewtopic.php?t=29957&highlight=timer1
They suggest stop TIMER1 before reading it or writing it because it's working on asynchronus mode. Still not sure what to do
Confused
---- GREECE ----
