I2C Slave with 33J12MC201
PostPosted: Tue Apr 15, 2008 10:03 pm     Reply with quote
I'm trying to set up a dsPIC33J12MC201 for I2C slave use as follows:
#use i2c(slave,Fast,sda=I2C_SDA,scl=I2C_SCL,address=0x08)
But I get the following error: Bad Option: SLAVE
The datasheet clearly indicates I2C slave support for this part. What gives? I'd really rather not have to implement all of this myself.
Matro
PostPosted: Wed Apr 16, 2008 1:54 am     Reply with quote
Notice that your slave address isn't compliant with I²C specification.
To be sure to have a correct address choose it in the range from 0x10 to 0xF0.
There is a few other possibilities but in this range all values are allowed.
Matro.
