Variable frequency PWM
umka
PostPosted: Wed Apr 16, 2008 2:38 pm     Reply with quote
I am trying to build a variable frequency PWM for to control the speed of either a single of three phase electric motor but am having trouble being able to set the period as a variable so its speed can be constantly changed.
I did a search and found something a while back but cannot find it now so any help would be appreciated.
I have a pic 18f4431 for power pwm if needed which I would think it is.
PostPosted: Wed Apr 16, 2008 2:53 pm     Reply with quote
Does this mean you want two separate frequencies, based on the motor
type ? Then you vary the speed by changing the duty cycle.
umka
PostPosted: Wed Apr 16, 2008 3:00 pm     Reply with quote
With an AC motor do you not have to vary the frequency to vary the speed? then the duty ratio will determine the current limit?
I may have this total wrong but i want to be able to have a PID speed controll on and ac motor either single or three phase.
