cyberant
RS232 does not work - ideas? |
Posted: Mon Jan 21, 2008 1:49 am |
main.h
Code: | #include <18F4525.h>
#device adc=8
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
#use delay(clock=8000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8) |
main.c
Code: | #include "main.h"
//#include <bootloader.h>
unsigned long zahl=0;
char buchst;
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_PLL_OFF);
while (true)
printf("enter char: \r\n");
buchst=getc();
printf("char: %c\r\n",buchst);
"enter char" is displayed but "char:" gets never displayed??(after I entered a char) - can there be anathing wrong with the code or is this a hardwarefailure? |
D-Kens
Joined: 09 May 2005 Posts: 35 Location: Toulouse (France)
Posted: Mon Jan 21, 2008 4:14 am |
How do you enter your char ? Did you check that the software you use (hyperterminal, or anything else) has the same settings as those defined in your RS232 settings, in main.h (9600 bauds, 8 bits, no parity...) : if you don't use the same "language" at both ends of the cable, your devices can't understand each others. |
cyberant
Posted: Mon Jan 21, 2008 9:43 am |
D-Kens wrote: | How do you enter your char ? Did you check that the software you use (hyperterminal, or anything else) has the same settings as those defined in your RS232 settings, in main.h (9600 bauds, 8 bits, no parity...) : if you don't use the same "language" at both ends of the cable, your devices can't understand each others. |
Ive solved it - it was a 1way RS232 cable... ![Rolling Eyes](images/smiles/icon_rolleyes.gif) |
Posted: Sat Apr 12, 2008 11:34 pm |
hello everybody
i am able to receive characters but how i do receive string of characters?
how do i receive a sentence? thanks for the informations! |
