problem with printf and const
curroortuno
PostPosted: Fri Apr 18, 2008 5:13 am     Reply with quote
I use CCS Compiler v4.065 and I have the following code:
const otra[3][* ]={
    "Weight=%u Kg"
    "Height= %u cm"
    "Age= %u years"
void main(){
   // Init LCD
   // I like in LCD: "Height= 185 cm"
   printf(lcd_putc,otra[1], 185);
But, when I compile, the message than I see in LCD is:
"Weight= %u Kg Height=185 cm"
Why does LCD show the first message? How do I solve this problem?
Thanks.
Matro
PostPosted: Fri Apr 18, 2008 5:33 am     Reply with quote
Try that :
char const otra[3][*]={
    "Weight=%u Kg",
    "Height= %u cm",
    "Age= %u years"
void main(){
   // Init LCD
Matro
PostPosted: Fri Apr 18, 2008 5:40 am     Reply with quote
Excuse me, this is my code:
const otra[3][*]={
    "Weight=%u Kg"
    "Height= %u cm"
    "Age= %u years"
void main(){
   // Init LCD
It is same that your code but LCD don't show "Height= 185 cm".
Matro
PostPosted: Fri Apr 18, 2008 6:26 am     Reply with quote
This is not the same as mine.
I added type to constant definition and commas at the end of each "cell" of array definition (except last).
Copy paste my code, try it and tell us about.
Matro.
PostPosted: Fri Apr 18, 2008 7:29 am     Reply with quote
Excuse me, again.
I have copied your code but LCD shows the same message:
"Weight=%u Kg Height= 185 cm"
LCD shows the first string though I write "otra[1]" in the printf.
Thanks.
Matro
PostPosted: Fri Apr 18, 2008 8:19 am     Reply with quote
And with this solution?
char* const otra[3]={
    "Weight=%u Kg",
    "Height= %u cm",
    "Age= %u years"
void main(){
   // Init LCD
Matro
Matro
PostPosted: Fri Apr 18, 2008 8:42 am     Reply with quote
    "Weight=%u Kg",
    "Height= %u cm",
    "Age= %u years"
void main(){
   // Init LCD
Matro
It seems that this is not supported by CCS... Sad
Maybe you can try all in a single line :
char const otra[3][*]={"Weight=%u Kg","Height= %u cm","Age= %u years"};
In case of a compiler bug.
Matro
PostPosted: Fri Apr 18, 2008 9:02 am     Reply with quote
Thank you Matro, but these codes don't solve my problem. Have you some idea more?
Matro
PostPosted: Fri Apr 18, 2008 9:21 am     Reply with quote
I've in the mind that this will never work...
CCS reference manual says that an array defined as "const" can't be accessed through a pointer. And that's what you are trying to do.
I think the best is to pass strings in RAM, either by using strcpy() function, or by using directive
#device PASS_STRINGS = IN_RAM
Matro.
PostPosted: Fri Apr 18, 2008 11:57 am     Reply with quote
"Weight=%u Kg",
"Height= %u cm",
"Age= %u years"
void main(){
// Init LCD
printf(lcd_putc, otra[1], 185);
You need to understand something about CCS. It's intended for small
embedded microcontroller chips, so because of that, the compiled code
is designed to be small.
Your example is based on the belief that CCS has a large run-time
module (such as MSCRT.DLL) that contains the entire printf parsing
mechanism. But it does not.
You are trying to pass the format string to printf at run-time. But CCS
doesn't parse the format string at run-time. It parses it at compile-time,
and creates a small, compact, specific code to handle the "%u" only.
If you also put in "%f", then it creates code for that too. But it's all
created at compile-time. It's hard-coded.
