Joined: 28 Mar 2008 Posts: 6 Location: 70 Industrial Way Wilmington, ma 01887
Inline assembly question with PCWHD CCS C compiler 4.071
Posted: Thu Apr 10, 2008 6:30 am
I built the PIC24H Demo code for Explorer 16 Board that came with my Microchip Explorer 16 Board using the Microchip C 30 compiler. Now I am porting the code to the CCS C compiler. So far so good.
void Delay( unsigned int delay_count )
temp_count = delay_count +1;
#asm
outer:
dec _temp_count
cp0 _temp_count <= this is line 51
bra z, done
repeat #3200
nop
repeat #3200
nop
bra outer
done:
#endasm
Any ideas?
Ken
Posted: Thu Apr 10, 2008 7:17 am
I suggest you use the CCS supplied functions delay_us() and delay_ms(). These function names are more descriptive than the Microchip delay() and delay_us() combination. Also in CCS style you can call the function directly with the desired delay instead of having to use a defined value.
