Hi fellows,
I have made an application using CCS. And i have made its ethernet interface in mikroC. Now i have two hex files.
How i can merge them and use the variables of one in other i.e variables of Ethernet module in CCS code.
Is this possible.....
if possible how i can it be done....??
Thanks..
Matro Guest
Posted: Tue Apr 08, 2008 2:31 am
Its almost impossible. Possbile is you very well know the variables locations in both hex. But It will be a huge programmation for doing so.
The best is definitely to port one of the C code in the other compiler.
It will 100x faster and 1000x easier.
