Software UART problem. |
Posted: Thu Apr 10, 2008 9:30 am |
What can be the problem in this.
The TX is coming from a MAX232 and is working on the same chip with the Hardware uart.
Code: | #include <18F2455.h>
#FUSES NOXINST
#FUSES NOWDT
#FUSES INTHS
#FUSES NOBROWNOUT
#FUSES PUT
#FUSES MCLR
#FUSES NOLVP
#use delay(CLOCK=4000000)
#use rs232(BAUD=19200,PARITY=N,XMIT=PIN_C6,RCV=PIN_C7,BITS=8,TIMEOUT=10,STREAM=com1,ERRORS)
#use rs232(BAUD=19200,PARITY=N,RCV=PIN_B1,BITS=8,TIMEOUT=10,STREAM=com2,ERRORS)
void Chk_com2(void){
char c;
if (kbhit(com2)){
c=fgetc(com2);
fputc(c,com1);
fprintf(com1,"_%x_",c);
//**Ext1 int**//
#INT_EXT1 //pin 22 int
void Ext_int1(void){
Chk_com2();
void main(){
ext_int_edge(1,H_TO_L);
enable_interrupts(INT_EXT1);
Matro Guest
Posted: Thu Apr 10, 2008 10:42 am |
Try this
#use rs232(BAUD=19200,PARITY=N,RCV=PIN_B1,BITS=8,TIMEOUT=10,STREAM=com2,FORCE_SW,ERRORS)
Matro |
Posted: Thu Apr 10, 2008 11:39 am |
The funny thing is, if I make a endless loop in main it's working.
Code: | void main{
while (1) {
char c;
c=fgetc(com2);
fputc(c,com1);
I think the problem can be the handling of Ext1 int?
Any sugest...
F |
Posted: Thu Apr 10, 2008 12:05 pm |
Solution in RS232 is the sw : SAMPLE_EARLY
F |
