DS1307 Driver
E_KARVELAs
DS1307 Driver
PostPosted: Fri Apr 04, 2008 7:03 am     Reply with quote
Hi
Does anyone have the DS1307 driver??
Can't find it inside Driver folder .
---- GREECE ----
Matro
PostPosted: Fri Apr 04, 2008 7:58 am     Reply with quote
You can copy the one of DS1305 or even 1302 and do some little changes to match with the 1305.
Matro.
elctronic(E_karvelas)
DS1307
PostPosted: Fri Apr 04, 2008 8:25 am     Reply with quote
Matro.
Hi
DS1307 has Two-wire serial interface I2C interface. Neutral
DS1305-2 are 3-Wire/SPI Serial Interface Confused
inservi
PostPosted: Fri Apr 04, 2008 8:38 am     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=23255&highlight=ds1307
You can find 'ds1307' in this wonderful forum in 'Code Library' there are other links.
Best regards,
dro.
in médio virtus
Matro
Re: DS1307
PostPosted: Fri Apr 04, 2008 9:03 am     Reply with quote
elctronic(E_karvelas) wrote:
Matro.
Hi
Indeed. Quick answer, bad answer... Razz
Matro.
