Sending and Receiving Strings between 18F8720 and 18F4320
picgirl08
PostPosted: Thu Apr 03, 2008 12:17 pm     Reply with quote
I am trying to send a string from the 18F4320 development board to the 18F8720 and then transmit that string to hyperterminal to display what is being read.
When I look at the output line of the transmitting micro (without them connected) on hyperterminal the string is being sent every few milliseconds.
When I look at the transmit line of the receiving micro to hyperterminal (when they are connected) It appears as though the string is only being received periodically. I was just wondering if I have to change the delay times or is it something else? I have used the kbhit function in the receiving string program.
Any help would be great! Thanks so much!! Very Happy
PostPosted: Thu Apr 03, 2008 2:45 pm     Reply with quote
Post the two programs. Make them be short and compilable without
errors. Here's an example of a short, compilable test program:
http://www.ccsinfo.com/forum/viewtopic.php?t=34127&start=1\
Also post your compiler version.
picgirl08
Receiving Microcontroller is a PIC18F8720
PostPosted: Thu Apr 03, 2008 7:25 pm     Reply with quote
This is the code for the receiving microcontroller, which is a PIC18F8720, 1 rs232 port is receiving a string from the transmitting Micro which is a PIC18F4320 and the other rs232 port of this micro is transmiting the string to hyperterminal. I am using the CCS C compiler Version 4.066
char inputstring[10];
void clearstr(void);
long timeout=0;
int i=0; //string count variable
do
while(!kbhit()&&(++timeout<25000)) //while nuthing at serial port
                                    // and quarter sec time < 25000
   delay_ms(10);
if((timeout<25000)&&(kbhit()))
   gets(inputstring);             //read in a string from serial port
                              //store it under inputstring
   timeout=0;
 if(inputstring[i]!='$')  //ck to see $ in lead character
   i++;                  //if not increment the string index
  if(inputstring[i]=='$')   //when the $ is found do this
   printf("Found String\r\n %s\r\n", inputstring);
   OUTPUT_LOW(PIN_B4);  //turn yellow on
   i=0;
   OUTPUT_HIGH(PIN_B4); //turn off yellow LED
clearstr();       //clear the input string buffer
delay_ms(500); //delay 1/2 a second
}while(true);
}//end of main program
void clearstr(void)
inputstring[0]=0;
inputstring[1]=0;
inputstring[2]=0;
inputstring[3]=0;
inputstring[4]=0;
return;
picgirl08
Transmitting Microcontroller is a PIC18F4320
PostPosted: Thu Apr 03, 2008 7:32 pm     Reply with quote
Here is the code for the transmitting Micro that is sending the string to the PIC18F8720. Basically we are trying to send a continuous string that the receiving micro can look at the characters and respond according to what the characters are.
#include <string.h>
int i=0;
char inputstring[10];    //array string of 10 characters long
do
i=0;
inputstring[i]='$';
i++;
inputstring[i]='O';
i++;
inputstring[i]='K';
i++;
inputstring[i]=0;
//puts(inputstring);
printf("%s\r\n",inputstring);
}while(inputstring[i]!=0);
inputstring[0]=0;
inputstring[1]=0;
inputstring[2]=0;
inputstring[3]=0;
inputstring[4]=0;
inputstring[5]=0;
}while(true);
PostPosted: Thu Apr 03, 2008 7:34 pm     Reply with quote
It's not compilable. It's missing the #include, #fuses, #use delay()
and #use rs232() statements.
picgirl.08
sorry
PostPosted: Thu Apr 03, 2008 7:38 pm     Reply with quote
Do I Copy all the Fuses from the .h file?
picgirl09
receiving code
PostPosted: Thu Apr 03, 2008 7:50 pm     Reply with quote
#include <18F8720.h>
#device ICD=TRUE
#device adc=8
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOOSCSEN                 //Oscillator switching is disabled, main oscillator is source
#FUSES BORV25                   //Brownout reset at 2.5V
#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOWAIT                   //Wait selections unavailable for Table Reads or Table Writes
#FUSES MCU                      //Microcontroller Mode
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#use rs232(baud=9600,parity=N,xmit=PIN_G1,rcv=PIN_C7,bits=8)
long timeout=0;
do
   i=0;
   Output_Low(PIN_A5);
   delay_ms(250);
   Output_HIGH(PIN_A5);
   delay_ms(250);
do
   delay_ms(10);
   timeout=0;
   i=0;
}while(true);
void clearstr(void)
inputstring[0]=0;
inputstring[1]=0;
inputstring[2]=0;
inputstring[3]=0;
inputstring[4]=0;
return;
picgirl08
transmitting Code
PostPosted: Thu Apr 03, 2008 7:52 pm     Reply with quote
#include <18F4320.h>
#device ICD=TRUE
#device adc=8
#FUSES XT                       //Crystal osc <= 4mhz
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES MCLR                     //Master Clear pin enabled
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
int i=0;
do
i=0;
inputstring[i]='$';
i++;
inputstring[i]='O';
i++;
inputstring[i]='K';
i++;
inputstring[i]=0;
inputstring[0]=0;
inputstring[1]=0;
inputstring[2]=0;
inputstring[3]=0;
inputstring[4]=0;
inputstring[5]=0;
}while(true);
PostPosted: Thu Apr 03, 2008 8:39 pm     Reply with quote
For 18F8720:
This line will generate a software UART. You shouldn't mix pins between
the two hardware UARTs. Either use C6 and C7, or use G1 and G2,.
Also add the ERRORS parameter. Your code has large delays in it
and this parameter will prevent lockups due to receiver overrun errors.
Example:
#use rs232(baud=9600, xmit=PIN_G1, rcv=PIN_G2, ERRORS)
#FUSES LVP
With this setting, if the PGM pin (pin B5) goes high, your PIC will lockup.
Change it to this:
#FUSES NOLVP
Do this in all your programs from now on. (same with ERRORS).
For the 18F4320:
#FUSES LVP
Again, change this to NOLVP. Do this in all future programs as well.
#FUSES PBADEN
If you're not using Port B for analog inputs, it's best to change this fuse
to NOPBADEN. This configures them as digital i/o pins.
Again, add the ERRORS parameter. Always do this.
picgirl08
thanks but still not receiving string!
PostPosted: Thu Apr 03, 2008 9:27 pm     Reply with quote
I made all of your suggested changes and Both programs are running, but when connected through rs232 cable the receiving end is never entering into the loop below, it just in continously going through the program without returning that true and blinking the yellow LED
   delay_ms(250);
   //printf("Getting String\r\n");
   timeout=0;
PostPosted: Fri Apr 04, 2008 12:18 am     Reply with quote
do
i=0;
inputstring[i]='$';
i++;
inputstring[i]='O';
i++;
inputstring[i]='K';
i++;
inputstring[i]=0;
Your code is too complicated.
The following loop sends "$OK", followed by carriage return and linefeed
characters, once every 500 ms.
   puts("$OK");
Change your receiver code so it's done in the same simple way.
(Get rid of all the timeout stuff for the initial testing).
