| on7nh
				| 30f4013 and TC74A5 (SOLVED) |
				|  Posted: Wed Apr 16, 2008 3:52 am |   |
				| Hello , i have a strange problem
 I make a I2C connection to a TC74
 the loop is working, bu i receive always a "0"
 what could be wrong ?
  	  | Code: |  	  | #include <30f4013.h>
 #device adc=10
 #FUSES NOWDT // Watch Dog Timer
 #FUSES EC
 #FUSES PR //Promiary Oscillator
 #FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
 #FUSES NOCOE //Device will reset into operational mode
 #FUSES ICS0 //ICD communication channel 0
 #FUSES RESERVED //Used to set the reserved FUSE bits
 #define XTAL_FREQUENCY 10000000
 #use delay(clock=XTAL_FREQUENCY)
 #use i2c(MASTER, SDA=PIN_F2, SCL=PIN_F3, FORCE_HW,slow)
 #use rs232(stream = RS232, baud=115200,parity=N,xmit=PIN_F5,rcv=PIN_F4,bits=8)
 int data;
 int ack;
 int fahr;
 Void main()
 set_tris_b(0xFFFF);
 While(1)
 i2c_start();
 ack = i2c_write(0x9A);
 ack = i2c_write(0x00);
 /* send start again */
 i2c_start();
 ack = i2c_write(0x9B);
 data = i2c_read(0);
 i2c_stop();
 printf("temp %D\r\n",data);
 delay_ms(200);
 Carl
 (edit)
 Cleared Force_HW in the I2C(master settings....
