CCS Ethernet Development Kit
info@ckmintech.com
PostPosted: Tue Apr 01, 2008 3:38 am     Reply with quote
Anyone has know how many RAM and ROM is required to implement a simple TCP/IP client by using the driver and example codes in this development kit?
I am planning to use a smaller pic for this project.
Rgds.
andrewg
PostPosted: Wed Apr 02, 2008 8:55 am     Reply with quote
CCS use a port of the Microchip stack. I have the v3.75 stack and am using it with the ENC28J60 chip.
I can remember compiling one of the demo examples. It included the HTTP server with a simple web page, and support for DHCP, DNS and ICMP enabled. It just squeezed into 32KB. Adding any significant functionality would have tipped it over.
Maybe disabling unneeded parts of the library would help. For example, DHCP requires UDP support. If you could live without DHCP, then you don't need UDP either. Maybe dropping UDP, DHCP and DNS would make enough room on a 32KB part if your application was simple enough?
IMO, the minimum program memory required is 48KB. 64KB would have me feeling a lot better, though.
Andrew
