Carl Tashian Guest
#locate usage |
Posted: Mon Nov 26, 2001 8:06 am |
I'm using #locate to reserve space for variables.. and I wonder, does #locate know the size of the variable being located? Can it prevent entire structs from being clobbered, or does it just handle the built-in types?
Thanks,
Carl
Original Post ID: 1316 |
Tomi Guest
Re: #locate usage |
Posted: Mon Nov 26, 2001 11:40 am |
The size of the type is reserved.
A sample list:
typedef struct {
char c;
float f;
int16 i;
} struct1;
char c1,c2;
char i;
struct1 y;
#locate y = 0x22 // the struct is 0x22-0x28 (last byte)
c1=c2=0;
i = 10;
y.i = 20;
.................... c1=c2=0;
0019: CLRF 2A
001A: MOVF 2A,W
001B: MOVWF 29 // c1 var. @0x29
.................... i = 10;
001C: MOVLW 0A
001D: MOVWF 2B
.................... y.i = 20;
001E: CLRF 28 // the last element (int16) of the struct
001F: MOVLW 14
0020: MOVWF 27
:=I'm using #locate to reserve space for variables.. and I wonder, does #locate know the size of the variable being located? Can it prevent entire structs from being clobbered, or does it just handle the built-in types?
:=Thanks,
:=Carl
Original Post ID: 1321 |
