boulder
Hardware UART |
Posted: Tue Mar 25, 2008 6:13 pm |
Can I use #use 232() setup a hardware UART without setup_uart()? Or can I just use setup_uart() without #use 232()? Do I have to use Force_sw for software UART when I use #use 232()? Or does it mean it's hardware UART if I don't use Force_sw in #use232()? My chip is PIC16886.
Thanks. |
Posted: Tue Mar 25, 2008 10:31 pm |
Quote: | Can I use #use 232() setup a hardware UART without setup_uart()? |
You normally only need setup_uart() if you want to change the baud rate
of the hardware UART at runtime.
Quote: | Or can I just use setup_uart() without #use 232()? |
No.
Quote: |
Do I have to use Force_sw for software UART when I use #use 232()? |
If you are using the hardware UART pins and you want a software UART
on those pins, then you must use FORCE_SW. That's because if you
specify the H/W pins, the compiler assumes you want to use the H/W
UART. If you want to override this, you must use FORCE_SW.
Quote: |
Or does it mean it's hardware UART if I don't use Force_sw in #use232()? |
If you specify the H/W pins, the compiler will use the hardware UART
by default.
To summarize:
On the H/W UART pins, you may specify a H/W or software UART. The
default is a H/W UART. You may force a S/W UART by using FORCE_SW.
On any other pins, only a software UART is possible. That's all it can do. |
boulder
Posted: Tue Mar 25, 2008 10:40 pm |
Thanks. Now my mind is clear about UART setup. |
Posted: Wed Mar 26, 2008 3:16 am |
hello, just a concern about FORCE_SW.
It means that both pins will be SW driven, right, and RS-232 SW routines will be added? I dont get it since the RAM and ROM used is still the same as without FORCE_SW.
In other world, what is the difference between using HW UART and SW one?
cheers guys. |
Humberto
Posted: Wed Mar 26, 2008 8:21 am |
Yes, SW routine must be added.
FORCE_SW do not generate code.
The main difference is that HW UART generate an interrupt (if it is properly enabled)
in the START bit of the incoming data. While that if a SW UART is used, in order to sense
the START bit it is mandatory to do a polling at a minimum equivalent rate of the period
of one bit, or 10X the expected baud rate.
Humberto |
Posted: Wed Mar 26, 2008 9:04 am |
One thing that may confuse here, is that the routines are not actually generated, till they are _used_. So you can change the #use RS232 line, and compile, and see no difference in the code size. Only is there is a putc, or a getc, _using_ this definition, will the code size actually change.
Posted: Wed Mar 26, 2008 12:17 pm |
now i see,
cheers |
