Randomized number selection question
rnielsen
PostPosted: Fri Mar 28, 2008 12:01 pm     Reply with quote
Greetings fellow campers...
I have the need to generate a number, randomly, from 1 thru 5 (or 0 - 4). These numbers need to have a weight assigned to them so that, say, the number 1 is selected 40% of the time, 2 is selected 30% of the time, 3 is selected 15% of the time, 4 is selected 10% of the time and 5 is selected 5% of the time. So they all add up to being selected 100% of the time.
I'm not a wizzard at algorithms or mathematics so I'm asking for input on which road I should head down to accomplish this. It doesn't need to be numbers, it could also be routines that are selected.
Any ideas out there?
Thanks,
Ronald
If at first you don't succeed, try doing it the way your wife told you to.
treitmey
PostPosted: Fri Mar 28, 2008 12:44 pm     Reply with quote
I'm no math wiz tho.
I would do rand int 0-99thus making 1% chance for each number
then run result through a if statment.
if(rnd<40)//1 - 40% time
result=1;
break
if(rnd>39 && rnd <70)//2 - 30% time
result=2
break
and so on...
Humberto
PostPosted: Fri Mar 28, 2008 8:52 pm     Reply with quote
Hola Ronald,
I'm agree with treitmey suggestion and I'm not a math wiz too.
#include <STDLIB.H>
#define RAND_MAX 100
int8 value, number;
   srand(1);
    (int8)value = rand();
    number = 0;
    do
       if((value >= 60)&&(value < 100)) // 40% chance to fall here
         {number = 1;  break;}
       if((value >= 30)&&(value < 60))  // 30%    "   "   "    "
         {number = 2;  break;}
       if((value >= 15)&&(value < 30))  // 15%    "   "   "    "
         {number = 3;  break;}
       if((value >=  5)&&(value < 15))  // 10%    "   "   "    "
         {number = 4;  break;}
       if(value  < 5)                   // 5%     "   "   "    "
         {number = 5;  break;}
      }while(foo);
Humberto
treitmey
PostPosted: Sat Mar 29, 2008 1:59 pm     Reply with quote
I think you need randmax = 99
0-99 gives you 100 ,... right
Is the randmax inclusive??
And since the rand num start with zero you could add one. rnd+=1
to get 1-100. That makes it a little easier to keep straight in your head.
Humberto
PostPosted: Sat Mar 29, 2008 9:39 pm     Reply with quote
Hi treitmey,
In the posted code, value never reach 100:
Yes, I think so.
In the posted code the rand num never start with zero, did you see srand(1)?
Humberto
treitmey
PostPosted: Mon Mar 31, 2008 7:53 am     Reply with quote
Sorry, perhaps I'm confused.
doesn't srand just seed the randomness?
I just was referencing 3.249 chm help file that says
for rand()
The rand function returns a sequence of pseudo-random integers in the range of 0 to RAND_MAX.
After thinking about it. I think your code will work. We don't need 1% probability to start with. Just equal probability, then you limit the equal probability to a range of 100 which I think will give 1% in the end.
Humberto
PostPosted: Mon Mar 31, 2008 9:06 am     Reply with quote
Yes you are right. The point is that srand() was used widely in a PC environment with
an OS running behind, were you can use the function time() to get a quasi random seed.
In embedded C this is not available (still). Wink
Humberto
rnielsen
PostPosted: Mon Mar 31, 2008 3:03 pm     Reply with quote
I've never needed to use rand() before and it's giving me strange results.
I've defined rand_max as 100 and 20 but the result from rand() is in excess of rand_max. I'm just trying to simulate it with mplab and I'm not sure if this is a bug with mplab or what. Is mplab supposed to work with rand() properly?
Ronald
PostPosted: Mon Mar 31, 2008 3:39 pm     Reply with quote
Define the value of RAND_MAX before the including of stdlib.h, otherwise the code below will be valid and your max value will become 32767.
copied from stdlib.h
#ifndef RAND_MAX
#define RAND_MAX  32767    // The value of which is the maximum value
                           // ... returned by the rand function
#endif
rnielsen
PostPosted: Mon Mar 31, 2008 4:11 pm     Reply with quote
Gotcha!
