bwhiten
SPI bus, 3.3V Master, 5V Slave |
Posted: Tue Mar 25, 2008 11:13 am |
The bus would be between two PICs as in the subject line. Will I need a level translator between the two for clock, DI and DO?
Master = 18F67J50, slave = 16F887. |
Matro Guest
Posted: Tue Mar 25, 2008 12:00 pm |
Here is the classical level shifter for I²C bus.
w w w . nxp . com / news / backgrounders / bg_esc9727 / images / bg_esc9727_1. jpg
Remove the spaces I insert to be able to post this link. ;-)
It perfectly applies here.
Matro. |
bwhiten
Posted: Tue Mar 25, 2008 12:34 pm |
From these replies I take the answer is yes. I have a very nice bidirectional level translator from TI I already use, TXB0104 that can handle some extreme speeds at 3.3 to 5 and is very reasonably priced for 4 I/O.
Does any one see any issue with this component that I haven't noticed?
Also the TXS0104 series for open-drain drivers like I2C. |
