24HJ256GP210 and progammable port pull-ups
mharris27
PostPosted: Mon Mar 24, 2008 7:03 am     Reply with quote
Hey all,
I have yet another problem with either the PIC24 uP or CCS. I don't know which. I am trying to pull-up the port D pins with software but it's not happening. I get .2v max on the port pins when I insert this line of code.
port_d_pullups(TRUE);
or
port_d_pullups(1);
anyone else having issues with this?
Thanks,
Mike
PostPosted: Mon Mar 24, 2008 7:26 am     Reply with quote
If it a device supporting 'per pin' pull-ups, then the syntax is:
port_d_pullups(0xFF);
To turn them all on. 'True', or '1' will only turn on the one on the lowest pin.
However it is most likely, that CCS haven't got this working yet...
mharris27
PostPosted: Mon Mar 24, 2008 7:56 am     Reply with quote
Thanks for the reply,
I tried your code suggestion and it did not work. I have an e-mail in to CCS support.
Mike
Edit:
For those who are having the same problems use this....
set_pullup(true, pin_xx); ///for specific pins
or
set_pullup(true); //for all pins
Charlie U
PostPosted: Thu Jun 30, 2011 8:52 pm     Reply with quote
Hello all,
And it appears that the pullup function (set_pulllup()) is broken for the PIC24FJ256GA106 family as well in the latest version (4.122). The function calls end up pointing to the wrong bits in the wrong registers.
Charlie (lurking in the background)
FvM
PostPosted: Fri Jul 01, 2011 12:02 am     Reply with quote
Yes, I filed a first bug report more than 18 months ago and a second one last year, thus I think, the problem should be basically known at CCS.
I didn't check other processors than GA106 family, but I won't be surprized if more are affected.
Although the pull-up issue is in my watchlist of pending bugs, it doesn't bother me, because I set PU/PD in SFR directly.
Charlie U
PostPosted: Fri Jul 01, 2011 5:59 am     Reply with quote
Hello FvM, thanks for the reply.
I'll submit a bug report today to jog their memory.
I am just starting to debug 2 new designs with PIC24 parts. Are there any other "features" aka bugs on your watch list?
Charlie
Charlie U
PostPosted: Mon Jul 11, 2011 8:17 am     Reply with quote
Just received an email from CCS support that the pullup problem will be corrected in the next release.
