I tried the CCS examples for saving a floating point number.
I tried to write a 1.0001 to starting local e2rom address of 38. What get's displayed is 255.000
write_float_eeprom(38,1.0001);
float_i_b = (float)read_float_eeprom(38);
fprintf(COMM_PORT2,"fVal:[%3.6f] \n\r"float_i_b); //DEBUG TEST
void write_float_eeprom(int16 e2_addr, float data) //e2_addr = Start of E2 rom address. Data = Floating point number to convert
int8 i;
for (i = 0; i < 4; i++)
write_eeprom(i + e2_addr, *(((int8*)&data + i) )) ;
float read_float_eeprom(int16 e2_addr)
int i;
float data;
*(((int8*)&data + i) = read_eeprom(i + e2_addr);
return(data);
Posted: Sat Mar 22, 2008 5:41 pm
int i;
float data;
return(data);
You have an extra parenthesis on the left side of the (*int8).
It won't compile.
You're missing the comma after the format string.
This won't compile either.
void test_display_flaot()
"float" is spelled wrong.
Therefore, this is not the real code that you tested. It doesn't compile.
Also, you should specify the PIC that you're using and your compiler version.
