A little guidance using strtok please
JerryR
PostPosted: Thu Mar 27, 2008 10:23 am     Reply with quote
I am attempting to parse comma separated fields from a GPS-generated (nmea-0183) array of chars using strtok. I am running into a problem that I need help with. Using 3.249 PCWH compiling code for a PIC18F4525 controller.
Here a code snippet:
float    UTC;                                               //Complete UTC float
int8     UTC_Hours;                                         //UTC hours
int8     UTC_Mins;                                          //UTC min
int8     UTC_Secs_Int;                                      //UTC seconds
int16    UTC_Secs_Frac;                                     //UTC frac seconds
char     Status;
float    Lat;                                               //Complete Lat. float
int8     Lat_Deg;                                           //Lat. Degrees
int8     Lat_Min;                                           //Lat. Minutes
int16    Lat_Min_Frac;                                      //Lat. Frac Minutes
char     N_S;                                               //North =1, S =0
float    Lon;                                               //Complete Lon. float
int8     Lon_Deg;                                           //Long. Degrees
int8     Lon_Min;                                           //Long. Minutes
int16    Lon_Min_Frac;                                      //Long. Frac Minutes
char     E_W;                                               //East =1, W =1
float    Speed;                                             //Complete speed float
float    Course;                                            //Complete course float
int32    Date;                                              //complete date
int8     Rx_CheckSum;                                       //8 bit checksum received
char     Term[1];
int8     Index;
char     *Field;
strcpy(Term,",");                                           //load delimiter ","
Field = strtok(Working_GPS_Str, Term);                      //parse to next delimiter
UTC =    atof(strtok(0, Term));                             //get UTC time float
Status =  strtok(0, Term);                                  //get status char (A or V)
Lat =  atof(strtok(0, Term));                               //get latitude float
N_S =  strtok(0, Term);                                     //get N_S char (N or S)
Lon =  atof(strtok(0, Term));                               //get longitude float
E_W =  strtok(0, Term);                                     //get E_W char (E or W)
Speed =  atof(strtok(0, Term));                             //get speed float
Course = atof(strtok(0, Term));                             //get course float
Date =   atoi32(strtok(0, Term));                           //get date
delay_us(1);                                                        //stopping point for
        //debugger
The ASCII string to parse is:
$GPRMC,161229.487.A,3723.2475,N,12158.3416,W,0.13,309.62,120598,,*10
All number (float) are parsed fine. However the "A", "N", "W" are parsed incorrectly. The results are: Status= '2' (0x32), N_S= '>', and E_W= 'K'.
Anyone see my mistake?
Thanks in advance!
Matro
PostPosted: Thu Mar 27, 2008 10:34 am     Reply with quote
Just add a line at the beginning where you set the string to parse. Just to see if the problem isn't there. Use a constant string for demo.
Matro.
JerryR
PostPosted: Thu Mar 27, 2008 10:57 am     Reply with quote
Thanks for the quick reply Matro. Good suggestion, but still same result. The solution will probably be pretty simple. Here's the code with the "canned" GPS string forced into it.
Parse_CkSum_GPS(*Working_GPS_Str)
char     Status;
char     Term[1];
int8     Index;
char     *Field;
strcpy (Working_GPS_Str, "GPRMC,161229.487,A,3723.2475,N,12158.3416,W,0.13,309.62,120598");
delay_us(1);
JerryR
PostPosted: Thu Mar 27, 2008 11:02 am     Reply with quote
And another thing... It doesn't matter what character I put in the "A" position, the result for Status is still '2' (ASCII).
Any other thoughts?
PostPosted: Thu Mar 27, 2008 11:07 am     Reply with quote
Strip the program down to essentials. Use a very short test string
that consists just of "A,B,C" or something like that. Get rid of most
of those variables. Then try to parse out the A,B,C chars. Post a
complete, compilable test program, with the #include,#fuses, #use
delay, and a main() and the printf() statement that displays the result
of the parsing. In other words, post a (very short -- 10 lines) program
that I can copy and paste into MPLAB and run in the MPSIM simulator.
Also post your compiler version.
PostPosted: Thu Mar 27, 2008 11:29 am     Reply with quote
char     Term[1];
Your Term array should be large enough to contain the string + terminating zero. Now it is 1 character too small and strcpy will overwrite memory with unpredictable results.
Second problem:
Strtok returns a pointer, not a value.
JerryR
PostPosted: Thu Mar 27, 2008 12:08 pm     Reply with quote
ckielstra, PCM:
Thanks for your replies. Yes, Yes strtok returns a pointer! I dropped my "*".
Thanks so much!
Matro
PostPosted: Thu Mar 27, 2008 12:14 pm     Reply with quote
I just think the same thing.
strtok() returns a pointer and not a value.
That's why it works when you use atof() that takes a pointer too in parameter.
Use that code:
Status =  *strtok(0, Term);                                  //get status char (A or V)
N_S =  *strtok(0, Term);                                     //get N_S char (N or S)
E_W =  *strtok(0, Term);                                     //get E_W char (E or W)
Matro
Thanks Matro
PostPosted: Thu Mar 27, 2008 12:33 pm     Reply with quote
Matro:
Yes, that's what I did to fix it. I didn't catch the pointer issue!
Thanks for your interest!
