Floating point trig
horkesley
Floating point trig
PostPosted: Wed Mar 19, 2008 1:28 pm     Reply with quote
I need to be able to do the following x=sqrt(float); and other floating trig. functions.
I believe the CCS compiler can't do this, am I correct?
Regards,
Horkesley Electronics Limited
PostPosted: Wed Mar 19, 2008 1:37 pm     Reply with quote
It's right there in math.h:
float32 sqrt(float32 x)
Here's the file location:
c:\program files\picc\drivers\math.h
It's also in the CCS manual. Please download the manual.
http://www.ccsinfo.com/downloads/CReferenceManual.pdf
SherpaDoug
PostPosted: Wed Mar 19, 2008 1:38 pm     Reply with quote
CCS has all the standard trig functions including sqrt() and they work on floats. It is rare that I would use a float on a PIC regardless of whose compiler because they take so much RAM & ROM. But CCS supports float math as well as anyone.
What is your application?
horkesley
Floating point trig
PostPosted: Wed Mar 19, 2008 3:58 pm     Reply with quote
Hi SherpaDoug, PCM programmer,
Thanks for the reply.
I received an error message 'only integers supported'.
I will investigate further.
SherpaDoug, my application relates to using radio to calculate the distance the receive is from several transmitters.
I then use trilateration to calculated the position of the receiver relataive to the transmitters.
I plan to achieve a position accuracy better than 1 metre.
I write a lot of code with VB.NET and 'C' for the AVR series of micro's.
But hope to use a PIC for this application.
Regards,
