Tomi Guest
Unexpected result... |
Posted: Thu Mar 27, 2003 12:58 pm |
Just tried to compile (and to make fun for myself ) the following sequence (the snippet calculates the distance between two points and converts SiRF x,y,z coordinates of a GPS to longitude, latitude and height coordinates).
And after downloading believe or not, the right numbers appeared on the LCD !
float distance,atm;
float x,y,z,a,b,e,ee,N,p,th,fi;
distance = 0.0;
atm = gXPos - gRefXPos;
atm *= atm;
distance += atm;
atm = gYPos - gRefYPos;
atm *= atm;
distance += atm;
atm = gZPos - gRefZPos;
atm *= atm;
distance += atm;
distance = sqrt(distance);
DeltaD = distance;
x = gXPos;y = gYPos;z = gZPos;
a = 6378137.0; b = 6356752.31424518; // Earth constants
e = sqrt((a*a-b*b)/a/a);
ee = sqrt((a*a-b*b)/b/b);
p = sqrt(x*x+y*y);
th = atan(z*a/p/b);
if (fabs(x) > 1.0e-40) Lon = atan(y/x)/PI*180.0;
else Lon = 90.0;
fi = z + ee*ee*b*sin(th)*sin(th)*sin(th);
fi /= p - e*e*a*cos(th)*cos(th)*cos(th);
fi = atan(fi);
Lat = fi/PI*180.0;
N = a/sqrt(1-e*e*sin(fi)*sin(fi));
N = p/cos(fi) - N;
Height = N;
Original Post ID: 13154 |
Sherpa Doug Guest
Re: Unexpected result... |
Posted: Thu Mar 27, 2003 2:13 pm |
:=Just tried to compile (and to make fun for myself <img src="http://www.ccsinfo.com/pix/forum/smile.gif" border="0"> ) the following sequence (the snippet calculates the distance between two points and converts SiRF x,y,z coordinates of a GPS to longitude, latitude and height coordinates).
:=And after downloading believe or not, the right numbers appeared on the LCD !
:= float distance,atm;
:= float x,y,z,a,b,e,ee,N,p,th,fi;
:= distance = 0.0;
:= atm = gXPos - gRefXPos;
:= atm *= atm;
:= distance += atm;
:= atm = gYPos - gRefYPos;
:= atm *= atm;
:= distance += atm;
:= atm = gZPos - gRefZPos;
:= atm *= atm;
:= distance += atm;
:= distance = sqrt(distance);
:= DeltaD = distance;
:= x = gXPos;y = gYPos;z = gZPos;
:= a = 6378137.0; b = 6356752.31424518; // Earth constants
:= e = sqrt((a*a-b*b)/a/a);
:= ee = sqrt((a*a-b*b)/b/b);
:= p = sqrt(x*x+y*y);
:= th = atan(z*a/p/b);
:= if (fabs(x) > 1.0e-40) Lon = atan(y/x)/PI*180.0;
:= else Lon = 90.0;
:= fi = z + ee*ee*b*sin(th)*sin(th)*sin(th);
:= fi /= p - e*e*a*cos(th)*cos(th)*cos(th);
:= fi = atan(fi);
:= Lat = fi/PI*180.0;
:= N = a/sqrt(1-e*e*sin(fi)*sin(fi));
:= N = p/cos(fi) - N;
:= Height = N;
There is no better way to astonish yourself than to try something really stupid... and have if work!
As written it seems the problem is solved at compile time.
Original Post ID: 13158 |
Ron Guest
Posted: Fri Mar 28, 2003 2:29 am |
Maybe for your next challenge you should try these calculations:
<a href="http://ralph.bucher.home.att.net/project.html" TARGET="_blank">http://ralph.bucher.home.att.net/project.html</a>
If it doesn't work, I certainly hope the American Navy is not using CCS on their Tomahawks!
Ron
:= distance = 0.0;
:= atm *= atm;
:= distance += atm;
:= atm *= atm;
:= distance += atm;
:= atm *= atm;
:= distance += atm;
:= else Lon = 90.0;
:= fi = atan(fi);
:= Height = N;
Original Post ID: 13179 |
Ron Guest
Posted: Fri Mar 28, 2003 2:31 am |
Ron
:= distance = 0.0;
:= atm *= atm;
:= distance += atm;
:= atm *= atm;
:= distance += atm;
:= atm *= atm;
:= distance += atm;
:= else Lon = 90.0;
:= fi = atan(fi);
:= Height = N;
Original Post ID: 13182 |
