I need to use only one Port B pin with an internal pullup. According to the datasheet this is possible by setting up RABPU[bar] and setting the proper bits in the WPUB register.
The other Port B pins are as follows:
Portb.4 = I2C Data
Portb.5 = I need this one to have its internal pull up enabled.
Portb.6 = I2C Clock
Portb.7 = Digital Output
I didn't see a specific function or command in the CCS libraries to modify the WPUB register and set or clear the RABPU[bar] register.
